Originally Posted by NSPYR
How do we go about installing a oil cooler for the 8th gen civic then ???
The 100ish hp little engine doesn't really create enough heat to require an oil cooler. And unless you installed a thermostat it would be more harmfull than good IMO.
If you want an oil cooler. See if there are any external oil lines or perhaps install a tee into the oil pressure gauge/sensor and route some oil through a cooler then tap into the oil pan or valve cover for the return.
I've not yet done my first oil change. But intial looks - you might be able to mount a oil fitler relocation adaptor and use that as a sytem to tee in a oil cooler.
I'd just spend the money on higher quality oil and see my threads on heat control..
