The cause for rev-hang
This hasnt been brought up in a while, atleast that i have seen, but today i was thinking that the revhang and the DBW delay had something in common. I tested the theory today while driving around.
I found out that if the clutch is pushed in while releasing the gas, (like a normal shift) the rev hang is there. When i let off the gas and waited to push in the clutch until the motor started to slow down the car, there was no rev hang. Now when i am driving and traffic slows down a little bit, not enough for brakes, the car doesnt start to slow down for about 2-3 second. Thats the DBW causing that. So the rev hang is caused by the DBW not letting off the accelerator for a delayed period of time. This could be a total coincidence, but i thought i would post this up, and let you decide for yourself. I hope this isnt a repost that has already been figured out, if so.........oops |
^^thats because your trying to fix it before the ECU has caught up to the peddle position. Push in the clutch, put the gas peddle to the floor and let off. Do that in a fast motion, and you will watch your RPMs only jump to about 2k. Do it in any non DBW car and the rpms jump almost immediatly, and go high. It acts the same way with the clutch out, while you are trying to get rid of the jittery feel, the ECU is still catching up to the position the gas peddle was at before you started to adjust.
#12 (permalink) |
The delay between when you take your foot off the gas and the butterfly on the TB closing is minimal. Go into your garage and turn the key to on and floor it, then back off, then floor it again (w/ the engine off of course ) . You can hear the motor on the butterfly closing and opening depending on the gas pedal. It is quick enough, it just chooses not to be .
#13 (permalink) | |
Boink
| Another Rev Hang Post (Brought car to dealership this morning) | nalinc23 | Civic SI | 17 | 11-10-2007 02:58 AM |
| Dealer says rev hang doesn't exist - get lost | LCG20 | Civic SI | 12 | 09-04-2007 05:45 AM |
| 06 vs 07 and Reflash vs Rev Hang | nycclaye | Bolt-Ons And All-Motor | 3 | 03-14-2007 09:52 AM |
| Return of the Rev Hang? | taejinah | Mechanical Problems & Technical Chat | 1 | 11-02-2006 07:43 PM |
| My RPM's dont hang up anymore??? | 06redsi | Civic SI | 11 | 04-25-2006 10:16 PM |
