Old 09-18-2007, 07:50 PM   #1 (permalink)
Retread's Avatar
Question P2422 Code... Aaaaargh
Keep getting this code P2422. EVAP Evaporative Emmision System Vent Shut Valve Close Malfunction.
I know they had a recall for 03' accords for this, but what about my 06' Civic?
Is this a warranty covered repair ? I have 36, 834 miles on the car. Have checked the gas cap, gasket, several times. Not the problem I believe.
It pisses me off that I have to pay $88 at the dealer just to get the same info about the code I got from AutoZone for free. Have not gone to the dealer for repair yet. If it's a warranty covered issue, I will, otherwise I will have aprivate mechanic service the car.
Anybody had this code come up before on there 06/07 Civics' ?
Thanks in advance.
Retread is offline   Reply With Quote
Old 09-20-2007, 12:54 AM   #2 (permalink)
iknowmysh1t's Avatar
3yr/36k miles means your not covered unless goodwill or extended. if so it is covered under warranty.
iknowmysh1t is offline   Reply With Quote
Old 09-20-2007, 01:43 PM   #3 (permalink)
MonkeyConQueso's Avatar
Armand
I take it you cleared the code and it came back? If so, then the evap system just pooped out. Not much you can do but take it to the dealer to be dealt with. Sorry to hear that man.
MonkeyConQueso is offline   Reply With Quote
Old 09-29-2007, 11:24 AM   #4 (permalink)
Retread's Avatar
Well. I did have to go to the dealer for service. It turned out to be a spider's nest blocking the EVAP shut valve. While there, they did the recall repairs that were needed. If they would have replaced a part, my extended warranty would have covered it, but no parts were needed. Runnin' good again, hopefully for a long time.
Old 06-14-2008, 06:57 PM   #5 (permalink)
a spider nest r u kidding me? just had my cel come on today pulled the code and it was P2422. Ionly have 17k on an 07. guess i should just take it to the dealer huh? thanks for any input.
tigey76 is offline   Reply With Quote
Old 06-14-2008, 07:08 PM   #6 (permalink)
nevertofast's Avatar
ummm sounds like you didnt tighten the fuel cap enough my man
nevertofast is offline   Reply With Quote
Old 06-14-2008, 07:16 PM   #7 (permalink)
i've got 45k on my 06 and haven't had any CELs knock on wood b/c my warranty expires in another 3k
whtdvl is offline   Reply With Quote
Old 06-15-2008, 12:38 PM   #8 (permalink)
R4DG's Avatar
Kin
3yrs/36k miles is bumper to bumper
5yrs/50k miles is powertrain
EVAP = powertrain
he still has power train warranty
R4DG is offline   Reply With Quote
Old 06-15-2008, 03:11 PM   #9 (permalink)
SpringfieldSkins's Avatar
Chris
Honda vent shut valves go bad all the time, that's probably what it is. Possibly a line to or from the vent shut valve came off too.
It's definitely not a gas cap problem. Loose gas cap and you get EVAP large leak detected, EVAP small leak detected and EVAP very small leak detected, usually all at the same time (sometimes just 1 or 2 of the 3 though).
SpringfieldSkins is offline   Reply With Quote
Old 06-15-2008, 03:48 PM   #10 (permalink)
Where is this evap shut valve?
killsw1tch is offline   Reply With Quote
Security code for replacement cd player? Quantum Mechanical Problems & Technical Chat 13 09-08-2007 09:26 PM
2 shades of Fiji Blue Pearl - paint code: B529P-4 (darker and lighter) abs0lutexer0 Inside and Out 30 09-01-2007 12:05 PM
P0443 code, please help! ominous8204 Mechanical Problems & Technical Chat 9 04-12-2007 02:29 AM
Where is the radio code??? Johannes I.C.E., Electrical, Security, & Navigation 18 01-25-2007 02:11 PM
Cheat code to override transponder! surf40 I.C.E., Electrical, Security, & Navigation 7 01-01-2007 12:29 PM
