Old 09-18-2007, 06:41 PM   #1 (permalink)
Sounds from Engine Bay Under Throttle
All,
Put my fears to rest. When I hit the throttle, usually when the engine over 3k rpm I hear the engine rev, but I also hear a gushing sounds. Almost like a shuuuuuuuuuuu from the engine bay. Seems to be coming from the passenger side. Quite noticable on the free way.
Is this normal? Mabye a loose hose, dirty air filter? Car has about 1000 miles on it.
Thanks for any info!
samualcc is offline   Reply With Quote
Old 09-18-2007, 08:57 PM   #2 (permalink)
jdecker's Avatar
james
I can't say that i have heard it before, but its probably normal. Maybe it is just some wind roar or your more sensitive to the sounds your car makes.
jdecker is offline   Reply With Quote
Old 09-19-2007, 02:08 PM   #3 (permalink)
Anyone else experience this?
Old 09-19-2007, 03:07 PM   #4 (permalink)
I'm not really sure what it sounds like from your description. Is it high pitched? Low pitched? Does it sound like wind noise or is it a squealing? When you hear it is it constant or does it vary periodically?
If it's a constant high pitched sound, not very loud over engine and road noise, then it could be the intake roar/noise (depending on who you talk to), which is normal.
rationull is offline   Reply With Quote
alarms sounds funny after stereo install civictunesforme Mechanical Problems & Technical Chat 0 08-26-2007 02:18 AM
New Car K20z3 Engine Sounds mrJLIEU Mechanical Problems & Technical Chat 16 06-04-2007 11:34 PM
throttle hesitation on 06 Si kingcivic06 Mechanical Problems & Technical Chat 3 03-19-2007 08:37 PM
Big-Bore Throttle Body for the K20 Ep3racer954 Forced Induction And Nitrous 2 02-12-2006 10:07 PM
06 si vs 02-05 rsx intake manifold and throttle body.. OneSi Forced Induction And Nitrous 11 12-28-2005 09:02 PM
