Shifting into 1st gear when at a stop...
Has anyone noticed that sometimes there is an ever-so-slight "engagement" or lunging of the car? VERY slight, but noticeable. I'm wondering if I've got a problem with my clutch, or if it needs to be adjusted in some way. It doesn't happen every time, but enough to concern me.
Whaaaaaaaaaaaaapsssh!!!!!
![]() Join Date: Feb 2007
Nick
google the style of driving of rev-matching if your doing it even from the slightest roll.
if not, and your completely stopped, I'd say that's not normal. I push in the clutch, put it in first and my car stays still til i let go of the clutch.
nah - i've been driving MT cars for a long while now, and never felt this. it's only when at a dead stop. it's like this - depress clutch fully. as i shift into first (just engaging the gear - NOT giving it gas at all), you can feel a slight lunging or rocking of the car. and it only happens the first time. if i were to keep the clutch depressed and put into 1st again, it won't do it. odd...
#4 (permalink) | |
it will happen pretty much every time as long as it is the first time i am shifting into gear after the clutch has been depressed. if i keep the clutch in, go back to neutral, then go back into 1st, it won't happen. i just don't want this to be a problem down the road that gets worse. i'm going to have the dealer check it when i go for my 1st oil change. also thinking of going Synchromesh or similar for my MTF.
#6 (permalink) | |
It sounds like the clutch friction disk may be sticking slightly. This causes what you are describing. When you push the clutch in and the clutch friction disk sticks the tranny gears keep spinning and when you try to put it in first the syncros basically push so hard trying to match the speed of the gears that it causes the car to move a little. Then the clutch disk breaks free and it goes in gear. Then if you keep your foot on the clutch and take it back out of gear it will go back in easily because the disk is already broken free.
This is most frequently caused by a contaiminated friction disk. If you have a leaking rear main seal (engine) or input shaft seal (transmission) you could be getting oil on the friction disk, causing it to stick. If your clutch isn't disengauging all the way (clutch worn out or misadjusted) it can cause a similar problem, but it usually will just speed the tranny gears back up when you take it back out of gear (foot still on clutch) and will do the same thing when you put it back in. |
#9 (permalink) | |
#10 (permalink) | |
#12 (permalink) | |
Think about it this way, when you are idling in neutral with the clutch engaged, the clutch disk and input shaft are spinning as are many if the internal transmission components (main gears, synchronizers...), and when you disengage the clutch, they take a moment to bleed off that rotational energy. If on the other hand your car didn't exhibit this characteristic to some degree, I'd say you have a problem with a bearing or something that is causing the main shaft to slow down too quickly. |
#15 (permalink) |
Unless you get it on paper, it will not be on record. So you will prob waste a couple of hours for them to tell you there is nothing wrong and end up with a paper saying nothing is wrong.
This has happened to me at the local dealer. Spent about 2 weeks in and out of the shop with nothing to show for it cause "we dont record that as it was not a technical problem" Therefore, I was not able to file a complain to H of A. It was nothing major, just the workers being stupid but still pisses me off.
| 1st gear questions? | y2kedar | Civic SI | 7 | 06-20-2007 03:57 PM |
| Memorial Day Thread | webby | Water Cooler | 31 | 05-28-2007 10:38 PM |
| Down Shifting To A Stop? | tim711 | Civic SI | 62 | 08-07-2006 10:14 PM |
| Inconsistent Rattle/Scrape Throughout 1st Gear | asm8thgen | Mechanical Problems & Technical Chat | 0 | 08-04-2006 11:16 PM |
| Lunge in 1st gear at very slow speed | Rummey | Mechanical Problems & Technical Chat | 12 | 07-18-2006 10:02 PM |
