#81 (permalink) |
A mod might want to put this link on the first post. Proof from Honda that it's okay to Blame Canada.
http://nhthqnwws111.odi.nhtsa.dot.go...7V399-1316.pdf |
#82 (permalink) | |
ambitious; but rubbish
#83 (permalink) |
No problem. If a mod wants to tack my earlier post with the engine compartment VIN pic onto the head of this thread, that'd be swell, too.
I'm really surprised Honda wants an actual punch mark applied to steel. Does anyone know if this is a government mandated procedure? I've had recall work on non-Honda cars, and the service manager just checked the "Service Performed" box on a screen. The event was logged to the file associated with that car's VIN and recorded electronically, no paint damage required. Maybe the seriousness of this recall makes a difference, as I doubt anyone was killed by a balky VW window regulator. |
#85 (permalink) | |
I am the Juggernaut!!!
#86 (permalink) | |
yes, "teh" is on purpose!
#87 (permalink) |
Honda is not looking good with the many problems with these Civics. I personally had Power window problems on my way home in Feb 07 with my FA5. All the suspension thuds clunking. Headliner rattles, Sunroof rattles, rear deck rattles. The list just keeps growing.
I rmrmeber picking up my 1st new Honda in 1986. A CRX. What a fun car. NEVER a prob. I put 80k on the car and got my next Honda a 92 Civic Si, no problems,then a 94 Acura GSR again no problems. 97 Prelude no problems, 00 CRV no problems. 03 Civic 4 door no problems. Need I say more? HONDA get your S%&* together. |
#88 (permalink) | |
Stephen "Vince" Carter
#89 (permalink) | |
I can't wait to get the 1st call from the dealership this am. Here is a copy of my to-do list for them. #1 Thud coming from front end when making turns from a stop and low speed. There was a TSB for this. My VIN isn’t covered, but this has been happening since my car was new. #2 Rattle from head liner, sunroof and rear deck. #3 Service Bulletin 07-055 (Vin is covered) #4 Change Oil #5 Rotate tires |
#90 (permalink) | ||
#91 (permalink) | |
#92 (permalink) |
Did you see the parts list Honda is sending to service departments? 10 O-rings, 2 disk brake hub bearing units, 1 drum brake hub bearing unit (0 guide pin tools). They aren't expecting to find much wrong, and you can bet that if a mechanic pulls a sensor and can't come up with a part-numbered O-ring, something that's "close enough" will be pulled from the universal O-ring selection to get your car off of his rack.
Here's what I think happened. At the plant, the sensors were being installed without a guide pin tool and/or lube, resulting in O-ring damage. Not every sensor, but enough. This may have been the accepted installation method, or the workers disregarded assembly instructions. Over time, a few trashed O-rings allowed bearing contamination and subsequent wheel separation, prompting an investigation. During the investigation, it was discovered that improper sensor installation was the culprit (whether by design or bad intentions), so every car produced to that point was suspect and subject to recall. All newly produced cars have their sensors installed with the guide tool. Two interesting points. The front ABS wheel sensor uses an identical mounting method. The FSM has no mention of a guide tool for installation of ABS wheel sensors. |
#93 (permalink) | |
The letter mentioned above also states that owners will be contacted. |
#94 (permalink) |
Honda recall affects 06-07 Civics (threads merged)
I just saw this on msnbc.com...wasn't sure if anyone had posted it yet.
http://www.msnbc.msn.com/id/20777346/ |
#95 (permalink) | |
Yeah. I heard about it. It sucks.
#97 (permalink) |
Kill Your Self Krew
they have a service bulletin and it list the vin numbers of the affected cars.
#98 (permalink) |
Kill Your Self Krew
VEHICLES AFFECTED
2006 Civic: 2-Door – From VIN 2HGFG1...6H500009 thru 2HGFG1...6H584624 2-Door Si – From VIN 2HGFG2.5.6H700084 thru 2HGFG2.5.6H713846 4-Door – From VIN 2HGFA1...6H500005 thru 2HGFA1...6H528911 2007 Civic: 2-Door – From VIN 2HGFG1...7H500001 thru 2HGFG1...7H539744 2-Door Si – From VIN 2HGFG2.5.7H700001 thru 2HGFG2.5.7H706051 4-Door – From VIN 2HGFA1...7H500001 thru 2HGFA1...7H502258 4-Door Si – From VIN 2HGFA5...7H700001 thru 2HGFA5...7H707417 |
#100 (permalink) |
Kill Your Self Krew
guess i have to take mine in
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/56393-new-recall-rear-bearing-revised-threads-merged.html
| The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: Safety Recall: Rear ABS Wheel Speed Sensor and O-Ring Inspection | This thread | Refback | 01-02-2008 02:58 PM | |
| The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: Safety Recall: Rear ABS Wheel Speed Sensor and O-Ring Inspection | This thread | Refback | 12-18-2007 04:14 PM | |
| 07 black si, hearing a poping or clicking noise? - ClubSi | This thread | Refback | 12-12-2007 12:42 PM | |
| 07 black si, hearing a poping or clicking noise? - ClubSi | This thread | Refback | 12-08-2007 04:04 PM | |
| Roll Call! Who with a non-Si has upgraded the rear anti sway bar? Si bar fits LX? | Andrei'sCivic | Suspension and Brakes | 13 | 07-01-2008 05:07 PM |
| Putting an Si Rear Sway on an LX sedan... pics | GoldCivic | Suspen | ||
