Old 09-10-2007, 03:31 PM   #1 (permalink)
Jim
Driver's Side Rear Window making noise
07 FA5, < 400 miles.
When I roll down the driver's side REAR window it makes a rubbery/squeaking sound. It is pretty loud and quite annoying. I dont have any tint. The window itself is REALLY clean. It did this from the moment I picked it up from the dealer.
I did a search and didn't find much, should I take this to the dealer and have them look at it?
jthoske is offline   Reply With Quote
Old 09-11-2007, 09:25 AM   #2 (permalink)
Jim
Noone has had this problem?
Bump
Old 09-11-2007, 12:10 PM   #3 (permalink)
sjlarue's Avatar
Call Me Jr Samples @ BR-549
Sounds like it's your glass rubbing on either your outer or inner mold (The part that runs along the door where the window meats the door). Maybe the dealer can adjust your molding with a putty knife or something. They can't do to much or you will get wind noises and water leaks.
Hope this helps
sjlarue is offline   Reply With Quote
Old 09-16-2007, 08:58 PM   #4 (permalink)
Brian Ko
hey i get this too on my fg2 passenger side window...and on top of the squeaking sound there are streaks...your not alone
kosi is offline   Reply With Quote
Old 09-16-2007, 10:42 PM   #5 (permalink)
sjlarue's Avatar
Kosi does yours sound like a scrape? And are the streaks ground into the glass? Or is it more like grease or black sealer?
AutoX 101 brooklynscat69 Autocross & Sanctioned Drag Racing 21 01-11-2008 09:22 PM
Difficult to replace drivers side airbags? mdenning Civic SI 0 08-02-2007 05:24 PM
Drivers Side Sedan Headlight sKiNNyazN5o4 Lighting, H.I.D.'s, & Neon 0 03-26-2007 09:12 PM
