Old 09-08-2007, 01:34 AM   #1 (permalink)
check engine light
i had my check engine light come on the other day and in the odometer area it said this:
"B12" in the bottom left corner
"15" in the bottom right corner
"Oil Life %" in the middle on the top
what does this mean? is it serious, i am 180 miles from home right now is it still ok to drive back?
Penguinizi is offline   Reply With Quote
Old 09-08-2007, 01:44 AM   #2 (permalink)
n00b retro whore
ethlar's Avatar
are you sure its the engine light and not the wrench light. Because Oil Life 15% means change oil and B12 is telling you what maintenances the car wants done to it. And those notifications are accompanied by the wrench light and not the CEL.
heres and easy test, get in your car and turn it on, when the light and those notifications come up, press the sel/reset button once and the light should go away and the message should change back to your odometer
Old 09-08-2007, 11:20 AM   #3 (permalink)
yea its the wrench, i am new to hondas i just assumed it was the check engine light ;x
anyways does this reset or how do i get it to stop doing it when i perform the maintainence?
Old 09-08-2007, 12:37 PM   #4 (permalink)
It means you are due for your B service along with engine air filter and your heppa filter replacement (the 2 symbol).
If you do the servicing at your dealer, which you should....they will reset it. It will not go out by itself, the info on how to reset it is in your owners manual if you have a read under the maint. minder section.
Cheers. PS: Your MIL ( Malfunction Indicator Light ) is a little diagram of an engine, not the wrench.
EDIT: as the above person mentioned you can hit your sel/reset button to make it go away for that drive. As soon as You start the car it will pop back up again, it gets annoying.
Tiller is offline   Reply With Quote
2006 Honda Civic Engine Information webby Garage 6 11-21-2008 04:23 PM
2006 check engine light and dont go over 3500 rpm bodydraggin Mechanical Problems & Technical Chat 15 07-21-2008 09:48 PM
check engine light csharp21 Mechanical Problems & Technical Chat 18 07-03-2007 06:47 PM
HELP New CAR. New COLD AIr Intake NOW the CHECK Motor light is on ????? coach2fast Garage 9 06-30-2006 10:43 PM
2006 honda world news webby Garage 0 07-25-2005 10:31 AM
