Old 09-07-2007, 09:50 PM   #1 (permalink)
SIcivic07's Avatar
Dan the DIME slayer
Si Sedan Pulling to the right...
have an 07 si sedan...just noticed today that the car is pulling to the right a bit, havent noticed it before, so i think it just started. but how could that be? what can cause such a thing? the car has 3500 miles.
SIcivic07 is offline   Reply With Quote
Old 09-07-2007, 10:19 PM   #2 (permalink)
Firestrife's Avatar
Keenan
the roads are crowned to the right causing the car to pull a little to the right after a bit. Try to drive on a very level road like a highway on the far left lane and see if it still does it.
Firestrife is online now   Reply With Quote
Old 09-08-2007, 01:08 PM   #3 (permalink)
SIcivic07's Avatar
Dan the DIME slayer
yep. still does it.
Old 09-08-2007, 01:26 PM   #4 (permalink)
Firestrife's Avatar
Keenan
Sounds like you need an alignment.
its possible to have a bad alignment in the beginning if you drive fast over bumps or potholes and such if not it wasnt aligned properly at the factory.
Old 09-08-2007, 01:39 PM   #5 (permalink)
NitrousG35's Avatar
Wild VTEC'n Bill
My FA5, which I bought on 6/22, was pulling to the left. Took it in and the dealer said the alignment was off. After the alignment, the car was straight as an arrow and seems to handle slightly better now. Have your alignment checked.
Old 09-08-2007, 03:24 PM   #6 (permalink)
D1BSI's Avatar
David
my alignment is slightly off as well due to a pot hole, pulls to the right and is super annoying..
NitrousG35.. did they align it for free?
D1BSI is offline   Reply With Quote
Old 09-08-2007, 03:58 PM   #7 (permalink)
SIcivic07's Avatar
Dan the DIME slayer
well i did drive into staten island yesterday, if any of you are in NY or know about the roads over here...i hit a bump or pot hole every 500 feet for an hour at 60 mph! so that may do it..the car is going in friday for other factory problems, ill tell them to check the alignment too..i mean its not TOO bad, but when the steering wheel is perfectly staright, the car goes a tad to the right. nothing too terrible i guess.
Old 09-08-2007, 04:10 PM   #8 (permalink)
06ggex's Avatar
brandon
before you go, just to make me fell better please check the air pressure in your tires. this may not be the problem but to explane. if you put a cup on its side it will role arround at the bottom of the cup. this is the same for the tires on you car. you may have a allignment problem, but it kills me the money people spend on allignments because of a simple problem. also you can try cross rotating you tires side to side if it is a tire it will pull the other direction.
Brandon,
06ggex is offline   Reply With Quote
Old 09-08-2007, 04:15 PM   #9 (permalink)
Wakeboarder11's Avatar
Tyler
it could be air pressure, a poor alignemt, or uneven tire wear.
Wakeboarder11 is offline   Reply With Quote
Old 09-08-2007, 04:20 PM   #10 (permalink)
Grimey's Avatar
I took mine in for this last week, and they told me it was the new DBW system and that's how it's setup.
I noticed it only does it when my foot is on the throttle, and that's exactly what they told me it does. When you lay off the gas, it stays straight. Well, mine does anyways.
Grimey is offline   Reply With Quote
Old 09-08-2007, 04:23 PM   #11 (permalink)
Firestrife's Avatar
Keenan
I dont see how DBW can effect the direction of your wheels.
Old 09-08-2007, 09:47 PM   #12 (permalink)
jdecker's Avatar
james
first week I had my car I had to take it in to get a new alignment.
jdecker is offline   Reply With Quote
Old 09-09-2007, 11:34 PM   #13 (permalink)
NitrousG35's Avatar
Wild VTEC'n Bill
Yes, they did. All under warranty. Car drives so much better afterwards.
Old 09-11-2007, 02:37 PM   #14 (permalink)
SIcivic07's Avatar
Dan the DIME slayer
1 whats DBW? and 2. checked my pressures on the front tires. the car was pulling to the right. just as someone said, my right tire had 31psi and the left had about 35psi...added some air to the right tire, steering wheel is straight, car is straight :)...however, when it goes in friday, ill have them check to see if it needs an alignment, since they will do it for free according to nitrousg35.
Old 09-11-2007, 02:59 PM   #15 (permalink)
Firestrife's Avatar
Keenan
DBW is Drive By Wire which is basically the new style which throttle position is controlled via the ECU in the car rather than a cable.
And yes that tire pressure can make a rather large difference.
Anyone with a coupe want a sedan now? Civic Pride Civic Coupe And Sedan 109 12-04-2008 04:35 PM
Marc's Sedan Review marc-o-lishuz Civic Coupe And Sedan 15 06-26-2008 01:23 PM
From Si Coupe to Si Sedan!!!!!!!!! cornerstrike Introduction & Pictures 29 09-03-2007 06:18 PM
Coupe vs Sedan JapTrapLove Civic SI 63 04-22-2007 11:23 PM
Problem with the Progress Sway Bar on an 07 SI Sedan. SIis4ME Civic SI 7 04-17-2007 03:34 PM
