#21 (permalink) |
GPS...odometer discrepancies and more
It is apparent that many do not understand GPS systems such as Garmin, Tom-Tom etc. and its accuracy. In short GPS does not calculate distance in straight lines but uses the route you are on. Your Garmin is a moving receiver and as such is always being updated as your car moves so it is always accurate. Further, accuracy with WAAS enabled (wide area augmentation system) is within 3 meters I believe. That means that the location indicated on your GPS (YOU ARE HERE) is within about 9 feet or less from where you actually are. GPS locations are much more accurate over any distance than either your odometer or roadside mile markers.
This whole discussion is about common speedometer/odometer discrepancies found in not only Honda vehicles but all vehicles by all manufacturers. It should be no surprise that since these components (speedometer/odometers) are mass produced they will not be: 1.) 100% accurate on each and every car. 2.) 100% equal in the amount of inaccuracy from one car to the next. That means all 2006 or 07 Civics are not 2% fast (or slow) but vary from car to car as well. Manufacturers of these devices like to keep within an overall tolerance...maybe +/- 5%. 3.) Inaccuracy is normal within a small amount but occasionally a larger amount happens and in those cases the speedometer may be swapped out under warranty. 4.) for those who asked if something can be done about nominal speedometer/odometer inaccuracy the answer is no. If it falls within that overall +/- acceptable range it is considered normal. Last edited by targettuning; 09-10-2007 at 04:23 PM. |
#24 (permalink) | |
#26 (permalink) | |
#28 (permalink) |
If you changed your tire size and didn't get the computer updated your speedometer and odometer will be off. The reading could be off quite a bit moving from 15" to 17" tires.
On my bro's car he wanted to go from 16" to 17" tires and the tire shop said the speedometer was going to be off around 3 to 5 km/h. Some one may want to some math and double check that number tho. |
| Question I can't find an answer for in my manual... | jthoske | Civic Coupe And Sedan | 4 | 09-07-2007 11:53 AM |
| someone who works at a part dpt pls answer this question | 20civic07 | Civic SI | 23 | 08-08-2007 02:48 PM |
| help with a question about getting a wing for my EX | Filippelli | Inside and Out | 7 | 05-10-2007 12:08 AM |
| A quick question. please answer | SilverEX | Civic Coupe And Sedan | 0 | 10-04-2006 09:49 PM |
