GGMIKEY
WTF is wrong with my electrical system!
Rep for anyone who can help me out:
Mods that would affect this: Foglights PNP HID's, wired with the relay harness Symptoms: When I put the key into the ON position....the dash lights flicker rapidly and it makes a clicking noise. Go to crank it into the start position.....nothing happens. I got a jump start...and the car started right up. Then while driving, if i put on my blinkers...the radio shuts down to a black screen. Same if i turn the foglights on. WTF. the tow truck driver thinks its the battery.....i hope thats all it is. ![]()
The original --> "J" <--
Alternator for sure bro. Be careful though, a friend had a similar issue in his Tc (wifes car tecnically lol) and the mechanic gave him a heads up about the pnp HID kit. He actually uninstalled it cuz the mechanic said the manager is a dick, and if he saw the HID kit he would probably try not to cover the alternator under warranty!?
Good luck! Keep us posted |
First I would take it to auto zone or some place like that that does free alternator tests. Or although not fool proof sometimes this works: start the car normally, and while the car is running, remove the negative battery cable from the the battery, (idk how easy this is to do on civic since I have yet to do anything with the battery), and if the car dies the alternator is most likely bad.
alternator or battery. check the voltage of the bettery while the car is off with a volt meter.should be between 12 and 13.as you start the car, check the voltage (need 2 people for this obviously), then start the car and check what volts the battery is getting, should be about 14.
this will diagnose if it is theh battery or alternator for sure. but immediatly from the sounds of it, i would say alternator. because when your driving, the battery doesnt use any of its charge...the alternator should be supplying all power needed to run the fogs/blinkers/radio. |
#14 (permalink) | |
#15 (permalink) | |
When I told him that I thought once the car was started teh alternator did everything. He said that on these "newer" vehicles, the battery still provides power to things like the ECU. I would think that it's the same on today's cars. I could be wrong since we're talking about a '06+ Honda compared to a '92 Chevy, but I'm pretty sure that even once the car's running, if you disconnect the battery it will die regardless of the condition of the alternator. Last edited by midnightex; 09-09-2007 at 02:29 PM. |
#16 (permalink) |
GGMIKEY
I'm thinking its the battery....I will find out tomorrow when I go to the dealer.
I forgot to mention...it does crazy stuff while its running. After I got the jump start and was driving home, if i put my blinker on it would turn the radio all the way off, to a black screen.
#18 (permalink) |
I'm pretty sure its the alternator. When my mom's alternator went out.. the radio went out while driving.. then I was like.. "wtf".. so I turned it back on and the car shut off. Pretty sure thats what went out.. idk why :x. Hopefully they replace it for you holmes.
#19 (permalink) | |
GGMIKEY
Ill find out tomorrow morning.
| list of all intakes available | honda06si | Bolt-Ons And All-Motor | 68 | 06-27-2008 03:34 PM |
| 2008 Accord Trim Specs / S2k CR Available for Order! | cbondhonda | Honda Industry News | 10 | 08-14-2007 01:08 AM |
| Building Up a System | (IVI) | I.C.E., Electrical, Security, & Navigation | 22 | 07-01-2007 06:48 AM |
| Looking for 2-way security system | marc-o-lishuz | I.C.E., Electrical, Security, & Navigation | 14 | 05-29-2006 12:01 PM |
| Need Help/Opinions On Building My System... | Kabs | I.C.E., Electrical, Security, & Navigation | 16 | 02-27-2006 12:06 AM |
