Oil filter cross check guide.. If you want to try larger filters
A guide of oil filters with 20X1.5 MM threads to help out if you want to or need to use a different oil filter.
OEM filter specs WIX Part Number: 51356 UPC Number: 765809513563 Principal Application: Acura (02-07), Chrysler Imports (92-06), Ford Probe (93-97), Honda (01-07), Infiniti/Nissan (96-07), Mazda (71-00), Mercury Villager (99-00), Mitsubishi (90-06), Saturn (04-07), Outboard Marine Engines, Various HD Equip. Style: Spin-On Lube Filter Service: Lube Type: Full Flow Media: Paper Height: 3.402 Outer Diameter Top: 2.685 Outer Diameter Bottom: Closed Thread Size: 20X1.5 MM By-Pass Valve Setting-PSI: 8-11 pay attention to this Anti-Drain Back Valve: Yes Beta Ratio: 2/20=6/19 Burst Pressure-PSI: 363 Max Flow Rate: 9-11 GPM Nominal Micron Rating: 19 Gasket Diameters Number O.D. I.D. Thk. Attached 2.475 2.173 0.233 Height Outer Diameter Gasket Diameters O.D. I.D. Thk. Ford Courier (72-82), Pinto (75-79) 4.828 2.921 2.734 2.43 .226 Chrysler (83-93), Eagle (89-93), Hyundai (86-89), Isuzu (81-85), 3.141 3.660 2.834 2.462 .200 Acura (88-05), Chevrolet (85-88), Dodge (91-96), Ford (88-96), Honda (72-05), Hyundai (89-07), Isuzu (85-04), Kia (01-07), Mercury (87-91), Mitsubishi (89-98), Subaru (87-07), 3.194 3.252 2.475 2.173 .233 Ford Probe (89-97), Mazda Cars & Trucks (83-96), Kia Sportage (95-02) 3.402 2.685 2.475 2.173 .233 Acura (02-07), Chrysler Imports (92-06), Ford Probe (93-97), Honda (01-07), Infiniti/Nissan (96-07), Mazda (71-00), MercuryVillager (99-00), Mitsubishi (90-06), Saturn (04-07), Outboard Marine Engines, Various HD Equip. 3.402 2.685 2.475 2.173 .233 Ford (92-97), Honda (00-07), Infiniti/Nissan (95-07), Mazda (97-07), Mercury (91-96), Saab (05-06), Subaru (88-07), CubCadet, Yanmar, John Deere, Kawasaki, Kobelco, Outboard 2.577 2.685 2.475 2.173 .233 http://www.wixfilters.com/filterlookup/index.asp Is a great place to find out technical information WIX filters. I use them to cross check the tech specs of other brands that don't post the info online. http://www.wixfilters.com/filterlook...&TempYear=2007 http://www.knfilters.com/search/appsearch.aspx another cross check http://www.amsoil.com/amsoillookups/...CrossRef.aspx/ http://www.knfilters.com/search/prod...x?Prod=HP-1010 Height: 3.75 in (95 mm)Outside Diameter: 2.781 in (71 mm)PSI Relief Valve: 13-17 Anti Drain Back Valve: Yes http://www.amsoil.com/storefront/detail.aspx?ID=6904 part number eoa13 Made with premium-grade full synthetic media. Ea Oil Filters feature advanced full synthetic nanofiber technology, making them the highest efficiency filters that are available for the auto/light truck market. EaO Filters provide a filtering efficiency in accordance with industry standard ISO 4548-12 of 98.7 percent at 15 microns, while competitive filters containing conventional cellulose medias range from 40 to 80 percent efficiency. Other factory cross checks AC PF2057 FRAM PH4913 FRAM PH5317 FRAM PH5343 FRAM PH7317 MOTORCRAFT FL2007 MOTORCRAFT FL822 ONAN 1220550 PURO L14620 WIX 51356 Disclamier Use this list at your own peril. Double check the info. If you are unsure just use the OEM filter. I am not responsible for any damage you do. |
Wix filter specs for s2000
Part Number: 51334 UPC Number: 765809513341 Principal Application: Acura (88-05), Chevrolet (85-88), Dodge (91-96), Ford (88-96), Honda (72-05), Hyundai (89-07), Isuzu (85-04), Kia (01-07), Mercury (87-91), Mitsubishi (89-98), Subaru (87-07), John Deere, Kobelco, Komatsu, Kubota, Onan, Toro & Yanmar Diesel All Applications Style: Spin-On Lube Filter Service: Lube Type: Full Flow Media: Paper Height: 3.194 Outer Diameter Top: 3.252 Outer Diameter Bottom: Closed Thread Size: 20X1.5 MM By-Pass Valve Setting-PSI: 8-11 Anti-Drain Back Valve: Yes Beta Ratio: 2/20=22/40 Burst Pressure-PSI: 280 Max Flow Rate: 9-11 GPM Nominal Micron Rating: 19 Gasket Diameters Number O.D. I.D. Thk. Attached 2.475 2.173 0.233 |
Note on Amsoil filters. While they may provide the absolute best filtering media. The canister is smooth. Which makes for a difficult removal! Bent one all to heck taking it off of my sportbike. Don't understand why a $$ filter can't offer something better. Fram makes them with the wrench ends and makes a model that is coated to provided more traction. K&N weld on a bolt head.
None the less I'll be using amsoil. Just need to find a good tool for removal and make sure I don't install it too tight. |
#5 (permalink) | |
This might be off topic, but this past weekend I changed my oil with a Wix filter for my R18. When I put my key in the II position, the "oil light" did not go away. I checked the fluid level, made sure the filter was hand-tight, and checked to see if the pan was leaking any oil. Put the key in the II position again and the oil light was still lit. I had to unplug the battery and everything is back to normal.
I've been using Mobil 1 EP oil filter since the first oil change, so this was my first Wix. I'll have to see what part number the filter was. |
#8 (permalink) | |
![]() this looks like it would be good for tight fit areas. Pretty neat. Would have been nice if Honda took a note from VW, MB, or Toyota and place the filter topside. The I could use my pella oil suction and never have to lift the car for oil changes. |
#9 (permalink) | |
Now before you guys go off in the search for the holy grail of larger oil filters be warned. Just because the canister is bigger doesn't mean much! Many people have taken apart two filters of different sizes only to find the exact same amount of media in each one. So you'd want to buy two and cut them apart just to confirm you're actually doing something and not just buying a larger filter canister with nothing more in it except empty space. Remember, companies like to make things modular so they have less parts laying around. Now, having said, the appropriately sized filter that is of higher quality is going to do more good than a larger filter of lesser quality. You want the highest efficiency possible while maintaining flow with an adequate amount of media to hold a large amount of dirt. http://www.oilfilterstudy.com http://home.mindspring.com/~cewhite3nc/index.html I never used/sold AMSOIL's old SDF line of filters because I thought they were overpriced for what you got. However, I'm loving the EAO line. |
| Oil Life | Elmacho | Civic SI | 32 | 12-02-2008 03:01 PM |
| Oil Change DIY | ethlar | Engine | 251 | 12-01-2008 10:46 PM |
| THE OIL FAQ - synthetics, intervals, weights, brands | jdrumstik | Mechanical Problems & Technical Chat | 98 | 10-16-2008 01:53 PM |
| Everything Oil: All you'll ever wanna know | atruhondagrl | Bolt-Ons And All-Motor | 14 | 06-16-2008 01:45 PM |
| Oil Filter | 604_ep3 | Civic SI | 2 | 11-20-2006 02:39 PM |
