Old 09-04-2007, 10:03 PM   #1 (permalink)
timbakersr's Avatar
tim baker
Nitrogen in my tires?
I've heard about this, What is the advantage? Is it expensive? Where do I get it?
timbakersr is offline   Reply With Quote
Old 09-04-2007, 10:06 PM   #2 (permalink)
Vince's Avatar
Stephen "Vince" Carter
Its more stable PSI vs. "air". I've heard its an added cost of course, you'd just have to ask around at tires shops.
Vince is offline   Reply With Quote
Old 09-04-2007, 10:08 PM   #3 (permalink)
You're doing it wrong!!
Gonzo's Avatar
As temperature varies, the tire pressure is more consistent than with normal air.
Not sure if there are additional benefits, I'd have to look into it.
Originally Posted by OEM_SI View Post
Are you a female?
Originally Posted by MFDOOM44 View Post
no but i have a vagaina
Originally Posted by twix562 View Post
Wow! Sleeper! I like!
Gonzo is offline   Reply With Quote
Old 09-04-2007, 10:09 PM   #4 (permalink)
xcopx's Avatar
Nee-kon Squad! #4
Here's what I found. http://www.automotivedigest.com/view...ticlesID=19827
Situation
1. NASCAR racers use tires filled w/ pure nitrogen
2. So do large commercial trucks, aircraft, even space shuttle
3. Some drivers say using tires filled w/ nitrogen improves fuel economy
4. Proponents say nitrogen maintains tire pressure longer, resists heat buildup
5. Skeptics say proper inflation is key, added cost of pure nitrogen not justified
6. Air we breathe is already 78% nitrogen
Significant Points
1. Proper inflation is key to improving fuel economy up to 3% whatever used to fill
2. Nationwide fewer than 10% of tire dealers offer nitrogen but number growing
3. Finding way into mainstream at growing number of tire dealers including Costco
4. Most dealers charge $2-$5/tire for initial nitrogen fill-up, generally offer free lifetime refills
5. Improved pressure maintenance important for sensitive automatic monitoring systems
Background
1. Nitrogen molecules bigger than oxygen molecules so seeps out more slowly
2. Nitrogen resists heat buildup better than air which contains moisture
3. Nitrogen reduces oxidation that can damage tire from inside out
4. Nitrogen is inert gas so no safety or environmental issues
xcopx is offline   Reply With Quote
Old 09-04-2007, 10:11 PM   #5 (permalink)
02civicsi's Avatar
I am the Juggernaut!!!
Nitrogen doesn't leak out as fast as regular air so you'll have more consistent pressure in the tires. There are only a few places who fill tires with Nitrogen but Costco is the only place near me who I know does.
02civicsi is offline   Reply With Quote
Old 09-04-2007, 10:12 PM   #6 (permalink)
Mr. Cowl Induction
NitrousG35's Avatar
Wild VTEC'n Bill
I got some Michelin Pilot Sport summer tires for my G35 at Costco. They fill all their tires with nitrogen. Supposed to be slightly lighter and prevents tire rot, although to be honest, I never had a tire rot out on me.
Old 09-04-2007, 10:33 PM   #7 (permalink)
02civicsi's Avatar
^^^ When are you getting your wheels? ^^^
BOT - I just wish more there were more places to get it.
Old 09-05-2007, 11:05 AM   #8 (permalink)
MikeDawg's Avatar
Situation
Significant Points
Background
The most important part with Nitrogen is #4 on the background. Nitrogen is inert, and that is its main advantage over plain air (~78% Nitrogen, ~20% Oxygen). Oxygen is not inert, in fact, oxygen is far from inert, causing reactions with almost anything (see #3 under background).
MikeDawg is offline   Reply With Quote
Old 09-05-2007, 11:09 AM   #9 (permalink)
LDB
LDB's Avatar
I will be switching as soon as I can find a place that does it. It's the way of the future.
LDB is offline   Reply With Quote
Old 09-05-2007, 11:11 AM   #10 (permalink)
cobra9244's Avatar
Sounds Interesting...
cobra9244 is offline   Reply With Quote
Old 09-05-2007, 11:12 AM   #11 (permalink)
Holy Crap!!!™
NBPRudy's Avatar
Randy
http://www.8thcivic.com/forums/showt...light=nitrogen
Originally Posted by ImTheVoiceOfGod View Post
I know it is possible, I see many people do it, but it wont allow me to post quotes in my signature.
Can someone webbyhelp me please
NBPRudy is offline   Reply With Quote
Old 09-05-2007, 11:28 AM   #12 (permalink)
MikeDawg's Avatar
Nope, didn't quite work, want to try again?
Old 09-05-2007, 11:32 AM   #13 (permalink)
Holy Crap!!!™
NBPRudy's Avatar
Randy
How's this?
http://www.8thcivic.com/forums/searc...archid=1283399
Old 09-05-2007, 11:33 AM   #14 (permalink)
si_dick's Avatar
Richard
The dealership should be able to do it for you.....but im sure there are places that will do it cheaper. Also all new cars come with nitrogen already in the tires.
si_dick is offline   Reply With Quote
Old 09-05-2007, 12:38 PM   #15 (permalink)
What makes you think that is true? I don't know that to be fact but doubt manufacturers (outside of premium brands) would go to the trouble of doing that when "air" is free.
My take on potential benefits is there are two. #1 is that nitrogen does have larger molocules than "air" and therefore less likely to leak through the tire wall. It will still leak if you have one (a leak) e.g. a nail in the tread. #2 Nitrogen contains no moisture and "air" is loaded with it. This internal moisture corrodes alloy wheels (steel wheels too) on the inside and produces damage to rubber on the inner side too.
targettuning is offline   Reply With Quote
Old 09-05-2007, 12:46 PM   #16 (permalink)
MikeDawg's Avatar
Close, but you know another term for rust is oxidation, "OXIdation". Guess what the OXI prefix to the word means, it doesn't mean water (H2O), it means oxygen. Oxygen is not inert, and causes these sorts of reactions. Oxygen will corrode alloy wheels, not the moisture.
Old 09-05-2007, 12:50 PM   #17 (permalink)
rmfa's Avatar
Ronnie
These nitrogen threads come up on all forums, I swear. Just keep your tires inflated consistantly, thats all you have to do. Forget about the nitrogen.
Old 09-05-2007, 01:26 PM   #18 (permalink)
Quantum's Avatar
http://www.howstuffworks.com/framed....tml?page=2&c=y
Quantum is offline   Reply With Quote
Old 09-05-2007, 01:28 PM   #19 (permalink)
mrdimsum's Avatar
kelly
why don't we fill our tires up with water... if theres a leak..... you can notice it right away... haha..... but it might rot out your tire....
mrdimsum is offline   Reply With Quote
Old 09-05-2007, 01:29 PM   #20 (permalink)
06si's Avatar
Kenny G
There is a shop around here that keeps begging me to do it. They want $40 to do all 4 tires. Does this sound like a good deal?
06si is offline   Reply With Quote
*8thCivic Tire Help 101* CrackThatTec45 Wheel And Tire Upgrades 50 08-23-2008 02:32 PM
(Twheel) See through Michelin tires... This is NOT a joke.. *MERGED* Chase Wheel And Tire Upgrades 43 08-07-2007 06:18 PM
Nitrogen in your tires tommyroo Wheel And Tire Upgrades 3 03-21-2007 06:22 PM
Making an EX look like a DX (snow tires w/pics) GlennS Wheel And Tire Upgrades 2 02-10-2007 04:46 PM
nitrogen in tires, is that SI only? buy N in a can? Markstudy Civic SI 16 10-26-2006 07:21 PM
