Old 09-10-2007, 08:47 AM   #21 (permalink)
ryker's Avatar
This is direct from Honda owners link
7,500 mi/12,000 km Scheduled Maintenance
Recommended service for your 2000 Honda Insight:
Replace engine oil.
Rotate tires.
You'll notice it does NOT have 3 or 5k oil change and it doesn't require oil filter changes at each service. This is normal guidline. Severe is 3750
So not all Honda's use the same guidelines.
For the 2007 Civic
http://www.ahm-ownerlink.com/mainten..._schedule.asp#
ryker is offline   Reply With Quote
Old 09-10-2007, 08:52 AM   #22 (permalink)
ryker's Avatar
Maintenance Minder A Scheduled Maintenance
Recommended service for your 2007 Honda Civic:
Replace engine oil (you'll notice it only says replace engine oil and not the filter)
1: If the message "SERVICE" does not appear more than 12 months after the display is reset, change the engine oil every year.
Maintenance Minder B Scheduled Maintenance
Replace engine oil1 and oil filter (now you replace the filter)
Inspect front and rear brakes
Check parking brake adjustment
Inspect tie rod ends, steering gear box, and boots
Inspect suspension components
Inspect driveshaft boots
Inspect brake hoses and lines (including ABS)
Inspect all fluid levels and condition of fluids
Inspect exhaust system#
Inspect fuel lines and connections#
There is no other guidlines on Honda homelink. The video says to just follow the maintance minder.
Old 09-10-2007, 08:58 AM   #23 (permalink)
ryker's Avatar
http://automobiles.honda.com/delivery_modules/mm.html
Another video link for those that still think a 1985 Honda is the same as a modern Honda.
Old 09-10-2007, 02:46 PM   #24 (permalink)
sjlarue's Avatar
Call Me Jr Samples @ BR-549
Refrence this to the other info that everyone else has sent you it is a copy of a 1985 civic Honda Service manual. Reference that to the websight and the Copy of the hillside honda thing.
If you don't believe that this is the service manual for a 1985 civic
here is the websight download it yourself.
http://pdftown.com/search/node/1985+...wiring+diagram
It's on page 46 of the first section.
Again the service intervals have not changed since at least 1985. The suggest that you change your engine oil more but, look they even tell you to change your oil filter at 7500 miles.
The lube points may have changed, the equipment that is replaced may have changed, the oil viscosity may have changed (and considering they have changed oil descriptions more than I can count, it's prob. different.) BUT THE MFG SUGGESTED INTERVALS ARE ESSENTIALLY THE SAME!
sjlarue is offline   Reply With Quote
Old 09-10-2007, 03:06 PM   #25 (permalink)
ryker's Avatar
Edit..
Modern Honda engines don't require an oil filter change at 7500miles. Reference:
Directly from Honda
As best I can tell service minder A would be a range of 3750 severe to possibly as high as 10k miles. My pure guess. Since my wifes Mercedes has a service minder oil life system and it gets up to 15k on oil changes.
People need to learn and read up on Modern engines before posting links of misinformation.
Old 09-10-2007, 03:11 PM   #26 (permalink)
ryker's Avatar
Hillside Honda didn't design or produce my car. Hillside Honda is open too make money by creating more service work.
Just becuase you've manage to find two sources of misinformation does not make the information correct.
Once again directly from HONDA motor company
Thereare no other guidlines on Honda homelink. The video says to just follow the maintance minder.
Old 09-11-2007, 04:46 AM   #27 (permalink)
sjlarue's Avatar
Are you unable to read and understand english? Modern Honda engines don't require an oil filter change at 7500miles.
Did you not read my post? I acknowledged this.
Did you not check the link? It was the Honda Service Manual. You can't get any more official than that.
Or are you too busy being a troll.
Your original Question was answered three times.
CLOSE THE THREAD!!!!!!
BTW "english" is SPELLED WITH A CAPITAL E. I can understand English. It's the people who can't spell or type it correctly, especially when there is a spell checker available, that need to go back to school and learn it.
Old 09-11-2007, 07:58 AM   #28 (permalink)
ryker's Avatar
I've still not been shown the parameters of when the ECU will determine the transmission fluid change.
Old 09-11-2007, 08:03 AM   #29 (permalink)
Firestrife's Avatar
Keenan
dude what do you want?
If it is recommended at a certain interval it is for your own good. You could go by the maintenince minder or mileage up to you, its just good practice and will probably give your car a much more longer life span, because 30k miles is a lot and whatever particles and break down of ATF can make the tranny run rougher.
Your ECU will not know that you have synthetic auto tranny fluid, Synthetic fluids lubricate better and start working at much colder temperatures than dino fluids.
might want to check up on what your talking before you argue a point.
Firestrife is offline   Reply With Quote
Old 09-11-2007, 08:30 AM   #30 (permalink)
ryker's Avatar
I agree. But I've not seen an official honda list of when the ATF fluid is to be changed. Don't understand why this pretty valid information isn't listed in the owners manual or on the honda website.
I've got some Redline d4 on order and will swap it in.
Old 09-11-2007, 09:17 AM   #31 (permalink)
dentrecords's Avatar
Can we stop the bickering please?
To the OP, if you aren't satisfied with the information provided about when to change the transmission fluid, perhaps a quick call to your dealer could answer the question.
Originally Posted by 2fast4u2
yee hawww
Old 11-07-2007, 01:12 AM   #32 (permalink)
Are you guys on meth?
We dont have a distributer cap/rotor. The 105KMILE service on that chart.
This is for the 05 civic im guessing.
pks17 is offline   Reply With Quote
Old 11-07-2007, 05:09 PM   #33 (permalink)
Are you retarded or something Ryker?
Are you retarded or something?
mynock250 is offline   Reply With Quote
