Old 09-03-2007, 04:25 AM   #1 (permalink)
sticky transmission
driving a 5MT. when im in netural and wiggle my shifter left to right, it sticks to the left sometimes.. and its real rough going left to right in netural.. i recently installed TWM cable bushings, and ever since i did, ive had this problem. i took a look at the bushings and nothing looks out of place. what else should i look at?
civic_coupe is offline   Reply With Quote
Old 09-03-2007, 11:42 AM   #2 (permalink)
you could spray a little silicone around the bushings that should help
ctrhatch is offline   Reply With Quote
Old 09-03-2007, 11:47 AM   #3 (permalink)
Hidy Ho Neighbor
GeezerSi's Avatar
-> Ken
Try a little lube.
Worse case... you might have to ream the bushing bores open .001" to .002" if their a little too close on the posts. If you have a '07, I believe an 8mm (.3150") reamer would do the trick
Good luck.
CLICK--> TOYS FOR TOTS
GeezerSi is online now   Reply With Quote
New 5-spd Auto Transmission Like/Dislike GMech Mechanical Problems & Technical Chat 80 03-19-2008 08:46 AM
My transmission is loud... volvo9 Mechanical Problems & Technical Chat 0 08-20-2007 09:11 AM
The transmission NIGHTMARE KrusT 954 Mechanical Problems & Technical Chat 13 06-23-2007 10:03 PM
Honda Begins Production at Georgia Transmission Plant webby Honda Industry News 2 05-19-2006 03:37 PM
