Old 09-01-2007, 06:26 PM   #1 (permalink)
07civicex's Avatar
Matt
where is the Trunk lamp fuse?
OK, My light in my trunk doesnt work. I went to the dealer today and they replaced the bulb, which didnt fix the problem. They were busy and told me to check the fuses. I checked the interior lights fuse and it looked fine?
What to do next?
07civicex is offline   Reply With Quote
Old 09-01-2007, 07:19 PM   #2 (permalink)
07civicex's Avatar
Matt
I checked all the fuses- which are OK.....Also the third brake light works, which is connected to the same wireing as the lamp- So its something with the lamp housing?
ARGH!
Old 09-01-2007, 07:23 PM   #3 (permalink)
i have a new housing if your interested
ctrhatch is offline   Reply With Quote
Old 09-01-2007, 10:05 PM   #4 (permalink)
radiocontrolhead's Avatar
Danny
How do you just happen to have a trunk lamp housing? That's not a common part at all.
Old 09-01-2007, 10:17 PM   #5 (permalink)
Tam Ngo
me and ctrhatch run a business during afterhours.
trystar is offline   Reply With Quote
Old 09-02-2007, 11:52 AM   #6 (permalink)
07civicex's Avatar
Matt
Any guesses?
Old 09-02-2007, 01:30 PM   #7 (permalink)
i have it beacuase i have a totaled 06 si so i have almost any part needed
Old 09-02-2007, 02:32 PM   #8 (permalink)
sjlarue's Avatar
Call Me Jr Samples @ BR-549
Do the rest of your interior lights work and radio if stock?
If no then it could one of the relay fuses under the hood. it would either be the 10A or the 7.5 under it.
sjlarue is offline   Reply With Quote
Old 09-02-2007, 04:56 PM   #9 (permalink)
07civicex's Avatar
Matt
The thing is the third brake light works fine. And if you look under there, the wiring for the trunk lamp branches off of the third brake. So that means its getting power just fine.....
Old 09-03-2007, 03:41 AM   #10 (permalink)
sjlarue's Avatar
However all the interior lights and the trunk light and a lot of the accesories run off a relay in the fuse panel under the hood, So if your interior lights don't work as well, it might be the one under the hood.
You could always use a volt meter to see if your getting power to the bulb to rule out the bulb.
Old 09-03-2007, 12:16 PM   #11 (permalink)
07civicex's Avatar
Matt
Yeah, I dont have a voltmeter- All my interior lights work fine though......So Im dropping it off at the dealer wednesday. I havd a gut feeling that its related to the lens assembly......
Old 09-07-2007, 11:43 PM   #12 (permalink)
07civicex's Avatar
Matt
Update- for those of you who care- dealer said that my trunk lock assy was faulty- causing the light not to work......
Old 09-08-2007, 03:39 AM   #13 (permalink)
sjlarue's Avatar
I'll have to remember that one.
Old 10-08-2007, 03:57 PM   #14 (permalink)
07civicex's Avatar
Matt
Yeah, kinda wierd huh? Been working fine since the new latch.
Trunk pop DIY For Non US EX & SI damb Exterior Style Mods 63 11-07-2008 09:36 PM
How can I get into the trunk Wilson Mechanical Problems & Technical Chat 19 12-06-2007 03:40 PM
Any Interest in CSL Style CF Trunk for Civic Coupe BLAZETIGER Inside and Out 54 08-25-2007 11:44 AM
what wires aer which jsb03f Bolt-Ons And All-Motor 3 08-01-2007 02:14 PM
Annoyed @ Rear Seat to Trunk Pass-Through Area klipsch41 Civic Coupe And Sedan 9 06-28-2007 12:28 PM
