Old 08-31-2007, 04:37 PM   #1 (permalink)
Foot / Clutch
I've read somewhere that your foot is supposed to be completely off the clutch pedal when not in use. I've read couple posts about how its supposed to be off when cruising, but i need a 2nd opinion.
If i just leave my foot slightly rested on the clutch while im accelerating, does this add more wear to the clutch? (Im not putting alot of weight on the clutch pedal but maybe resting my foot on there)
locomotived is offline
Old 08-31-2007, 04:40 PM   #2 (permalink)
Ct_Sidan07's Avatar
yup says it in your owners manual
Ct_Sidan07 is offline
Old 08-31-2007, 04:44 PM   #3 (permalink)
radiocontrolhead's Avatar
Danny
I believe when you're resting your foot lightly on the cluth you are engaging the throwout bearing against the clutch spring so that it's acctually spinning when it shouldn't. I did this too on my last car and after understanding more about the clutch mechanics have never rested my foot on the clutch pedal.
radiocontrolhead is offline
Old 09-01-2007, 01:56 AM   #4 (permalink)
DJ'sRREX's Avatar
THE HULK
yup ur car will blow up if you do
DJ'sRREX is offline
Old 09-01-2007, 02:30 AM   #5 (permalink)
06civictx's Avatar
Tim
06civictx is offline
Old 09-01-2007, 06:28 AM   #6 (permalink)
thats what ur dead rest pedal is for. ur suppose to keep ur foot there when ur not using your clutch
07nbpsi is offline
Old 09-01-2007, 06:29 PM   #7 (permalink)
NRM
NRM's Avatar
Mike Nguyen
The clutch is a very sensitive piece of machinery. You can already tell when you use it during daily driving that it's a very precise piece of equipment, so it's best to be off it as much as possible and let it do it's work. If it's not fully engaged or fully disengaged there is some slippage going on and over time will wear it down.
Same with leaving your hand resting on the shifter while driving. It causes some movement within the gearbox that also contributes to wear.
NRM is offline
Old 09-02-2007, 03:35 AM   #8 (permalink)
maximo61170's Avatar
gino
wikipedia said you are riding your clutch even if you rest your foot on the clutch when you are just coasting.
and we all know riding the clutch = death.
maximo61170 is offline
Old 09-02-2007, 06:03 AM   #9 (permalink)
whos_1st's Avatar
Thomas
whos_1st is offline
Old 09-02-2007, 06:20 AM   #10 (permalink)
windforce's Avatar
Omfg, are you serious? I leave my hand on my shifter 75% of the time...! Damn, my gear box is doomed!
windforce is offline
Old 09-02-2007, 01:58 PM   #11 (permalink)
Skunk who....?
SiNISTER SiNDY's Avatar
Shawn
Clutch Rule?
Do you ever smell it? I mean, when you rest your foot on it?
SiNISTER SiNDY is offline
Old 09-02-2007, 02:01 PM   #12 (permalink)
Go Gators!
Firestrife's Avatar
Keenan
Rule of Thumb when it comes to the transmission. You want to spend the least amount of time touching the shifter and clutch.
Firestrife is offline
Newbie guide for Manual Transmissions Tastycakes Mechanical Problems & Technical Chat 131 07-02-2008 01:05 AM
Exedy Hyper Single Stage III Clutch Kit: Part Details (PIC Heavy) blueroadster Forced Induction And Nitrous 103 12-18-2007 10:23 AM
resting my foot on the clutch...is it bad? megahurts Driving Experience 14 07-09-2007 09:45 PM
heel and toe shifting good read 2evolved Civic SI 12 09-27-2006 06:23 PM
ACT Clutch Kits, Flywheels and Greddy SP2 Exhaust skittleslegend Civic SI 43 06-22-2006 07:34 AM
