Old 08-31-2007, 12:24 PM   #1 (permalink)
hondasi006's Avatar
what is the best way to lube your moonroof/sunroof
sometimes it seems like it doesnt slide back so smoothly as it used to. ( from the dealership i remember seein this cloudy white kinda lube) whats the best stuff to lube the tracks up with. i would assume you just put it on the tracks rite.
hondasi006 is offline   Reply With Quote
Old 08-31-2007, 12:25 PM   #2 (permalink)
Well you could use white lithium grease. Honda makes some :) I use it to lubricate my clutch and throttle cable on my bike.
achapman is offline   Reply With Quote
Old 08-31-2007, 12:32 PM   #3 (permalink)
hondasi006's Avatar
i guess i could pick that up at like any auto parts store rite
Old 08-31-2007, 12:37 PM   #4 (permalink)
Yes sir.
Old 08-31-2007, 12:38 PM   #5 (permalink)
hondasi006's Avatar
thanks
Old 08-31-2007, 01:22 PM   #6 (permalink)
sjlarue's Avatar
Call Me Jr Samples @ BR-549
I think that you should use something like a silicon lube to do the job. Auto store have this as well.
DIYNet. websight says to use silicon. just google sunroof lubricant it should be about three or four down.
sjlarue is offline   Reply With Quote
Old 08-31-2007, 01:27 PM   #7 (permalink)
hondasi006's Avatar
ok now which one is it
Old 08-31-2007, 01:36 PM   #8 (permalink)
sjlarue's Avatar
the Silicon, Crude lubes will eat the rubber of the seal.
Old 08-31-2007, 01:37 PM   #9 (permalink)
hondasi006's Avatar
ok so any silicon base lube will work
Old 08-31-2007, 01:43 PM   #10 (permalink)
sjlarue's Avatar
yep, I just PMed you the link to the sight
Old 08-31-2007, 01:58 PM   #11 (permalink)
amdhunter's Avatar
1) Get a real pretty girl.
2) Sit her on the open sunroof
3) Play some nice bassy music.
4) Repeat if desired.
amdhunter is offline   Reply With Quote
Old 08-31-2007, 02:11 PM   #12 (permalink)
sjlarue's Avatar
I'd love to but my sexy wife is two fiddy plus and would prob. put a small DF in the car.
Old 08-31-2007, 03:13 PM   #13 (permalink)
Hidy Ho Neighbor
GeezerSi's Avatar
-> Ken
That's what it looked like to me last time I looked at the tracks.
CLICK--> TOYS FOR TOTS
GeezerSi is online now   Reply With Quote
Old 08-31-2007, 03:34 PM   #14 (permalink)
A silicone based lube would work fine too. Either or, you could even use vasoline if you wanted to.
Old 08-31-2007, 03:47 PM   #15 (permalink)
sjlarue's Avatar
Vasoline is petrolium based, it will degrade the rubber seals and such. That's why the silcon lube.
Old 08-31-2007, 07:47 PM   #16 (permalink)
sjlarue's Avatar
How To Do It.
Here Is a step by step that DIY put out. AND I read it wrong earlier. OOOOPS! You use silicon on the rubber but lithium on the hinges and tracks.
Sorry. Thought I had better check before posting it up.
http://www.diynetwork.com/diy/ab_par...271509,00.html
Can Jiffy Lube handle Si oil change? cool si Civic SI 47 04-16-2007 12:41 AM
Oil change experience at a Mobil 1 Lube Express andyman1080 Garage 1 02-07-2007 08:36 PM
Jiffy Lube Scam Video!!!!!!!!!! cornerstrike Water Cooler 3 01-17-2007 11:59 AM
Jiffy Lube airportguy770 Civic SI 27 09-23-2006 01:07 AM
What kind of lube for suspension bushings? Dale_K Civic SI 2 04-24-2006 12:04 PM
