Old 08-26-2007, 04:13 PM   #21 (permalink)
Wakeboarder11's Avatar
Tyler
okay today or tomorrow ill check the connections for any loose connections and examine the ballasts and bulbs. Ill try swapping bulbs and ballasts if the connections arnt the problem and let you guys know what it is then. Thanks for the input
Wakeboarder11 is offline   Reply With Quote
Old 08-26-2007, 04:16 PM   #22 (permalink)
striker_1818's Avatar
I HATE Stephanie
swap bulbs...
if the other bulb turns pinkish it is in fact a ballast problem which i seriously doubt but if it lights up white with the supposed bad ballast and if the other ballast lights up the other bulb pink then you know the bulb colorshifted bad and the bulb in fact is defective.
striker_1818 is offline   Reply With Quote
Old 08-26-2007, 04:54 PM   #23 (permalink)
caveman74's Avatar
Kevin
That is a result of a bulb going bad. You got a faulty bulb. PnP kits will do that..
caveman74 is offline   Reply With Quote
Old 09-04-2007, 10:39 PM   #24 (permalink)
Tyler
Ok guys thanks for all of the input. Caveman, i decided to take your advice since i know you deal with headlights on a normal basis. I emailed the ebay member who i bought the kit from and he sent me 2 new bulbs all the way from china for free! No shipping or anything! I put the new one on my car today and it was infact a bulb problem (Thank god). If you look closely at this picture, the bulb on the left is cloudy in the middle bubble part on the inside of the bulb and there is a little crack below that too. The new bulb is on the right.(Sorry for the bad pics i used my cell phone)
And now theyre good as new! Thanks again everyone!
Old 09-04-2007, 10:50 PM   #25 (permalink)
caveman74's Avatar
Kevin
Glad everything worked out. HID bulbs have a long life span, but when they get old they will dim or just be bad . Look at the older Acura TL's 99-01 most of those are fading.
Old 09-04-2007, 10:51 PM   #26 (permalink)
I HATE Stephanie
the "cloud" is the salt which is normal. wait a couple of days then take out your new bulb and u'll see the same "cloud" you refer to
Old 09-04-2007, 10:53 PM   #27 (permalink)
Supreme Pizza!
Izzy's Avatar
I was just about to say that. But I responded to you in another thread instead... you suck.
Old 10-22-2007, 09:39 AM   #28 (permalink)
vtecpete's Avatar
Pete
I think theres a problem that goes further then the bulbs. I got a friend with a 07 EX coupe with 10,000K HID and his driver side is significantly brighter and bluer then his passenger side. we always made fun of him for it he got his off ebay also. But now recently my 07 Si coupe is having the same problem, and again the DRIVER SIDE is bluer and brighter, i also have ebay HID (XenTec) my buddy has a different brand. Now i notice in ur pic that the DRIVER side light is brigher and more pink...i cant help to think that its either a really really big coinincedence or theres an actual problem with the eletrical in our vehicles.
btw, i have changed all my headlight fuses from 10amp to 20amp and my main headlight fuse to 30amp
vtecpete is offline   Reply With Quote
Old 10-22-2007, 02:03 PM   #29 (permalink)
Jason
there's ur problem rite there.
Old 10-23-2007, 08:08 PM   #30 (permalink)
Chris
i've heard that when a 4300k bulb starts to turn pink is about to die. i could be wrong but try switching bulb to other side to see if it could be the ballast.
nolimit179 is offline   Reply With Quote
Old 10-23-2007, 08:09 PM   #31 (permalink)
Whos The Whore NOW
07mugencivic's Avatar
Toe Knee
dosent look that pink....any pic in the night
Old 10-23-2007, 08:11 PM   #32 (permalink)
Supreme Pizza!
Izzy's Avatar
It could also be partially due to angle of how you're looking at it. Both sides do NOT have equal beam patterns, the driver side will point inward (and downward) a little more than the passenger side.
I had a XenonDepot PnP kit a few years ago, and didn't have that problem. There could be quality control issues, so...
Old 10-23-2007, 08:56 PM   #33 (permalink)
The McGyver ofall McGyves
portabuddy's Avatar
Bart Koscow
... DONT BUY EBAY LIGHTS AND NOT EXPECT PROBLEMS...
Right?
portabuddy is offline   Reply With Quote
Old 10-23-2007, 10:39 PM   #34 (permalink)
I HATE Stephanie
or...
rock the new pink hids because before it was blue but now the hype is pink!!
Old 10-24-2007, 12:40 AM   #35 (permalink)
jackolee's Avatar
who did you buy your kit from??? if its a cheap dealer than you just got ripped off
jackolee is offline   Reply With Quote
Old 10-24-2007, 01:23 AM   #36 (permalink)
I HATE Stephanie
u do realize even the most expensive hid kits are assambled the same way with the same components, right?
Example: Mcculloch vs a 50 buck hid kit.
Same pieces and assambled the same without any testing but just pure copy of the hella generation 3. why do you think almost all kits look like theirs?
Are these HID's ok? Hondacivicsi23 Lighting, H.I.D.'s, & Neon 23 05-28-2007 01:57 PM
HID's in my 07' Si... roadrunner1659 Lighting, H.I.D.'s, & Neon 12 12-31-2006 02:40 PM
Highbeams w/ HID's brooklynscat69 Lighting, H.I.D.'s, & Neon 19 10-18-2006 12:40 AM
6000K vs. 4300K Hids chriskurn Lighting, H.I.D.'s, & Neon 12 10-11-2006 09:09 PM
Questions about Lights (HIDS) Kabs Lighting, H.I.D.'s, & Neon 6 11-17-2005 09:19 AM
