Old 08-26-2007, 01:26 AM   #1 (permalink)
FG207Si's Avatar
Remote Amp Wire!?!?!?!
Wats up everyone im hooking up my amp+sub to the stock system tomorrow so has anyone found an easier place to tap in for the remote wire, because i really don't feel like pulling out the stock head unit if i don't have to..
thanks
FG207Si is offline   Reply With Quote
Old 08-26-2007, 01:41 AM   #2 (permalink)
FG207Si's Avatar
any suggestions......
Old 08-26-2007, 10:13 AM   #3 (permalink)
SkunkSpray's Avatar
did your civic come with the aftermarket amp and or bass package, if so In the trunk there should be a harness that already has the turn on wired, If not then you will prob have to run one from the deck, one question though, why do you want to keep the stock deck.
SkunkSpray is offline   Reply With Quote
Old 08-26-2007, 10:20 AM   #4 (permalink)
20strong's Avatar
Marcus
There is one in the fuse block also. If you check out the DIY audio section there is a couple.
20strong is offline   Reply With Quote
Old 08-26-2007, 01:30 PM   #5 (permalink)
FG207Si's Avatar
i just have a regular si with the premium sound, and for know i am keeping the stock headunit becasue i want to keep the clean stock look, and later on when i can afford it i want to get a double din in dash with all the goodies...
Old 08-26-2007, 09:07 PM   #6 (permalink)
FG207Si's Avatar
Old 08-26-2007, 09:10 PM   #7 (permalink)
there's a little light blue wire on the right side of the plug on the stock amp... all u have to do is take off the center console to get to it... pretty easy... sorry i don't have pix from when i did mine...
Old 08-26-2007, 09:20 PM   #8 (permalink)
FG207Si's Avatar
thnx.. and just to make sure the factory amp is under the center console ???? and how many plugs are down their so i don't get mixed up if their is more than one.
Old 08-27-2007, 10:35 AM   #9 (permalink)
SkunkSpray's Avatar
Here is a DIY for stereo install if you scroll down you'll see a wiring diagram, this might help find the factory amp turn on.
DIY: Aftermarket radio Install in an EX
Old 08-27-2007, 10:42 AM   #10 (permalink)
Ignorance is Bliss
Qshooter151's Avatar
Jordan
thanks for the tip, i will be needing this wire eventually...
Qshooter151 is offline   Reply With Quote
Help, Amp wire from stock deck mykicks007 I.C.E., Electrical, Security, & Navigation 14 07-11-2008 01:21 AM
Amp Remote On How-To - Civic Sedan w/ Pics Mobieus I.C.E., Electrical, Security, & Navigation 22 03-28-2008 01:22 PM
wire questions (remote/ line out/ power) 07k20z3ftw I.C.E., Electrical, Security, & Navigation 1 08-08-2007 01:43 AM
Remote wire slamminarm I.C.E., Electrical, Security, & Navigation 3 03-02-2007 01:48 AM
Need help installing locating remote wire connection? buzz4life85 Do It Yourself Articles 1 07-12-2006 01:52 AM
