low coolant level
my Si has ~4000 miles on it... the coolant level always seems to be a little low when the engine is cold (slightly below the line)... when the engine is warm however its above the line - but not by much
its been fine, no overheating, no problems at all..... but ill be installing my injen CAI soon and i know some coolant leaks when you replace the lines so i dont know if i can afford to lose any more coolant my questions are 1) should i even be worried? 2) how would i go about adding coolant if i need to? does the cap basically just screw off of that 'bottle' with the blue coolant? 3) can i just add a little bit of straight water or do i have to buy some kind of (honda?) engine coolant? thanks
Usually equal parts, but I always buy premixed. Is there a fill on the reservoir? If so, then yeah you can just add it there. Or you can put it in the reservoir and when it heats up, if there is too much, it will just be deposited in the reservoir.
It doesn't have to be honda branded, but you can use that. It's all the same. |
I can't answer your question about the diff. colored coolants, but the owner's manual has the specs on what type of coolant to use, if the stuff you have matches those specs, I'd imagine you're GTG.
The main reason I wanted to post was to second what the OP said about the coolant level seeming to be a bit low. I have about 800 miles on my FA5 and the coolant level showing in the reservoir been just under the "low" mark when the engine's cold and just over that mark when warmed up since I got it too. |
I would not use a anti freeze that has been sitting around a while.
You are better off for $15 going and buying the new prestone which is 100% safe for Honda's, Toyota's and other imports. It even states in on the outside label. Why not spend a little on the heart of keeping your engine cool! |
There is usually both a full cold and a full hot line. Is it below the cold line when cold, and above the hot line when hot? Or is there just one line? The plastic bottle is just a overflow reservoir. When coolant heats up it expands a little and some of the coolant in the radiator is purged into this bottle. When you shut your car off and the coolant cools back down, the coolant is basically drawn back out of this bottle into the radiator. As long as the level in this bottle is close to the recommended level you are fine.
As far as mixing coolant goes, most newer cars use an extended life coolant and most have their own color. I wouldn't mix old green coolant with newer extended life coolant. I don't know how much honda charges for their own brand, but you can get universal extended life coolant at most auto parts stores for $10-15 per gallon. It is usually a better deal if you buy it unmixed because you basically get two gallons once mixed 50/50 with water. |
#11 (permalink) | |
After you install your intake remove the radiator cap and add coolant to it. After you drive the car for a while let it cool down completely (never remove a radiator cap on a hot engine!) and check the coolant in the radiator again and top it off if necessary. Then check the overflow bottle and top it off if needed. |
#12 (permalink) |
Go to Auto store and buy the right stuff; blue, green, orange etc. For general "maintenace" like this I would get the 50/50 otherwise you will have to mix it and when you are only doing a little, you make more of a mess.
Use your thumb as a guage. No don't stick it in like a dipstick :-). With the engine cold, put it on the reservoir parallel to the low line. If it is below your thumb then fill it back to low. My thumb is about an inch wide for comparison. The only time you should be worried is if you fill it to the cold line and then run the car, after the car cools, there is nothing left in the bottle.....call a mechanic. |
#13 (permalink) | |
#14 (permalink) | |
#15 (permalink) | |
| Coolant leak | CaliGuy | Mechanical Problems & Technical Chat | 18 | 07-18-2007 11:58 PM |
| engine coolant question... | FusionSi11 | Mechanical Problems & Technical Chat | 7 | 06-05-2007 10:14 PM |
| Coolant...? | hoanger | Mechanical Problems & Technical Chat | 3 | 05-09-2007 10:25 AM |
| A/C not cold because of low coolant? | junsu | Mechanical Problems & Technical Chat | 1 | 11-22-2006 06:05 PM |
| How to install heat shield intake gasket and bypass TB coolant on 06 si. | 06redsi | Civic SI | 30 | 08-16-2006 11:20 PM |
