Old 08-20-2007, 10:46 PM   #1 (permalink)
Rallyecivic's Avatar
can't shift into 1st?
So I was at a stop light today and tried to go into first but it wouldn't go in?
I had to try like 6 times till it finally slammed in...this happened in my older integra too...whats the cause of this problem? anyone else experience this?
Rallyecivic is offline   Reply With Quote
Old 08-20-2007, 10:50 PM   #2 (permalink)
CaliGuy's Avatar
J. M. back by popular demand!
Check your tranny fluid...Only thing I can think...Did it happen more than once? Is this a consistent problem?
Old 08-20-2007, 10:54 PM   #3 (permalink)
i've had the car for about almost 2 weeks...and has only happend twice..
Only got 1k miles on it...cant imagine tranny fluids low?
so no one has had this problem?
Old 08-20-2007, 10:56 PM   #4 (permalink)
Mookie469's Avatar
Ed
Did you check your shift cables?
Mookie469 is offline   Reply With Quote
Old 08-20-2007, 10:59 PM   #5 (permalink)
nayilsi's Avatar
happens to me.... almost every other day.
whats the word again ??? notchy gearbox.... thanks Honda.
Old 08-20-2007, 11:00 PM   #6 (permalink)
bulletSisedan's Avatar
Jamil
Take it back to the dealer this is not a very common problem with these cars so it should be checked out.
bulletSisedan is offline   Reply With Quote
Old 08-20-2007, 11:04 PM   #7 (permalink)
nayilsi's Avatar
umm we have to show them right ???!?!
theyl be like... OOO LOOK IT WORKS nuthings wrong it shifted fine we didnt feel it...... MOVING ON.
Old 08-20-2007, 11:18 PM   #8 (permalink)
Yea that's why I don't even feel like going to the trouble to make an appointment for them to check it out...just a waste of time..
Old 08-20-2007, 11:25 PM   #9 (permalink)
I've had it happen to me a few times, but also in different gears when I first had the car for the first 2 weeks. Afterwards, it seemed to go away. Maybe it needs breaking in? lol Just keep driving it and if it keeps doing it after a week or 2. I'd bring it to the dealership.
taffysi is offline   Reply With Quote
Old 08-21-2007, 12:17 AM   #10 (permalink)
autumnalfalls's Avatar
Kyle
Had it happen to me a few times. Just place the XMSN in neutral, release the clutch, rev the engine a little bit, push the clutch in, and slide it into first.
I think its just the dog teeth are not in direct correlation with the dog teeth that engage the driven gear. If the gears are not spinning, the synchros can not do their job either. Hence placing the XMSN in neutral and giving the engine a slight rev/blip of throttle with the clutch engaged. Depress the clutch and place it in gear.
http://auto.howstuffworks.com/transmission1.htm should give you an idea of how this works.
autumnalfalls is offline   Reply With Quote
Old 08-21-2007, 12:28 AM   #11 (permalink)
n00b retro whore
ethlar's Avatar
to avoid the problem i almost always go from neutral > second > first when the lights about to turn green. Im not sure what mechanically is happening, but it helps reduce the problem
Old 08-21-2007, 12:31 AM   #12 (permalink)
udumkid's Avatar
Rene....
Is the car moving at all when this happens?
udumkid is offline   Reply With Quote
Old 08-21-2007, 09:51 AM   #13 (permalink)
volvo9's Avatar
Andrew
This is normal and something that happens on every manual transmission. Don't slam the shifter next time just let the clutch out in neutral and try again, it'll go in this time. To not have it happen put the car in 1st as your coming to a stop and going about 1 to 2 mph.
Old 08-21-2007, 09:56 AM   #14 (permalink)
black07coupe's Avatar
uhmmm if you downshift thru the gears when coming to a stop, it will keep this from happening in all gears. say you are in forth coming to a stop... downshift to 3rd, let it roll, and right before a stop just hold the clutch in and go thru 2nd and 1st. trust me, this used to happen to me, but as long as i go thru the gears most of the time when i come to a stop, its fine. mine slides into first without any effort at all.
black07coupe is offline   Reply With Quote
TWM Shift Knob SALE Until July 15th! TWM Performance TWM Performance Short Shifters 4 07-12-2007 03:26 PM
Memorial Day Thread webby Water Cooler 31 05-28-2007 10:38 PM
1st gear hesitation, then RPM hang after shift... Doppler Bob Mechanical Problems & Technical Chat 5 05-16-2007 11:07 PM
Feb Shift Knob Sale From TWM! TWM Performance TWM Performance Short Shifters 4 02-21-2007 05:31 PM
07 Problems todsulli Mechanical Problems & Technical Chat 33 01-29-2007 11:38 AM
