Closed Thread
Old 09-20-2007, 10:26 AM   #61 (permalink)
alexv305's Avatar
Alex Valledor
Originally Posted by BubzSI
I promised a couple people on here to post a nice DIY on my P2R Spacer and Gaskets. So here it is..
I could not post in the DIY:Engine Section-- So I posted it here.
Mods please move if you can.
Time to Install: 1 Hour (including taking pics)
[center]
Thats pretty much about it.
Fairly easy to install, but I've done alot of work on K-Series in the past.
**I am nor is 8thcivic.com, partners, or sponsors NOT responsible for damage, or anything you do based on this walkthrough**
Did you check to see if the return coolant hose from the bottom of the Throttle body was slighly bent because of the extra length the spacer takes up? What Im talking about is the two coolant lines that connect to the lower side of the throttle body, that most people bypass using the TB coolant bypass DIY. I didn't do this, however I did notice that the bottom return line was very slightly bent on the radiator return (black bar that connects the lower throttle body line to the nipple on the bar). Has anyone else noticed this?
alexv305 is offline
Old 09-21-2007, 12:35 PM   #62 (permalink)
Joe
This is a nice easy mod, did this yesterday along with the shifter cable bushings, took no time at all and fitment is perfect. Cant really tell the difference but its only a few horses so i wasnt expecting much-
BlackPearlSI is offline
Old 09-21-2007, 05:10 PM   #63 (permalink)
Dumb question. I noticed you didn't drain the coolant. This is doable without draining?
mellowbob is offline
Old 09-21-2007, 05:45 PM   #64 (permalink)
^^ i don't see why you have to drain the coolant. it has nothing to do with the radiator or hoses.
Si_Jeff is offline
Old 09-21-2007, 06:02 PM   #65 (permalink)
Driversound's Avatar
Yor Moma
I'm gonna do the same mode with the thermal gasket but with a Helix spacer.
Driversound is offline
Old 09-22-2007, 03:59 PM   #66 (permalink)
Joe
You do not have to drain the coolant- i left all my hoses connected to the throttlebody anyway, there is enough room to manouver with them still on
Old 09-22-2007, 08:17 PM   #67 (permalink)
galaxygrey13's Avatar
Ignacio
Can i do it with the stock upper radiator hose and CAI without cutting anything?
galaxygrey13 is online now
Old 09-22-2007, 10:41 PM   #68 (permalink)
DakidzSi's Avatar
George
Originally Posted by HanCivicSI
Spacer in, IMG in also. Works like a charm. I had to cut about an inch off of the Injen CAI elbow to allow for a better fit. I'm sure you don't "have" to do this but it definitely made the install easier. Before the elbow was creasing a little. Now it fits fine. I also used a g-flex upper radiator hose to snake around the intake. Stock hose will not work. You could also go a cheaper route and use an all rubber flexible hose as well. Here are some pics with the spacer, flex hose and IMG installed. Thanks Corsport!
I also noticed with the IMG installed, I could no longer fry eggs on the intake. LOL
BEFORE
AFTER
Great job! I'll have to do the same with my car's upper radiator hose. I noticed a little pinch with the CAI I have installed. What a PITA it was to get the 90 on the intake. I'll post picks when I get them.
DakidzSi is offline
Old 09-25-2007, 02:20 PM   #69 (permalink)
Ozzie
Hearing Noises
i have installed the P2R spacer with two gaskets one on each side just like BubzSI in his DIY only difference i have an Injen CAI. After installing it and letting the car idle for about 5 minutes i test drove it around the block when i got back i noticed a sort of noise coming from the vacuum pipe the comes out of the top of the throttle body. the noise is sort of like if air is not passing through correctly. anyone have any insight or have had this same issue? thanks.
ozfizzle is offline
Old 09-25-2007, 02:23 PM   #70 (permalink)
no leaks here... get a can of brake cleaner and spray it where you think the leak is... if the car starts to idle funny then you found your leak... it's very hard to find a leak just by sound....
bizzybearfigiblue is offline
Old 09-25-2007, 02:33 PM   #71 (permalink)
Ozzie
i will definitely try that but my car does not seem to idle at the present moment it stays steady. wouldn't my car idle minutes after being on if it had a leak?
ozfizzle is offline
Old 09-25-2007, 03:06 PM   #72 (permalink)
with as sensitive as these cars are... it should idle funny... but since it's not... it should make finding the leak that much easier...
Old 09-25-2007, 03:14 PM   #73 (permalink)
Ozzie
thanks i will try what you recommended and get back to you
ozfizzle is offline
Old 09-25-2007, 07:37 PM   #74 (permalink)
DakidzSi's Avatar
George
I've noticed a little hiss but I think that's from my CAI intake. I'll have to look into it a little closer to be sure. I know that the bolts for the TB have to be torqued to 16ft/lbs and that's what I did but it might require just a little more.
DakidzSi is offline
Old 09-26-2007, 07:07 PM   #75 (permalink)
vicfalc09's Avatar
NHBP FTW!
I just ordered this and received the product today, the bolts they sent are a brass color which I dont like and the plug is plastic instead of the metal one like on the first post....anyone else experience this??
vicfalc09 is offline
Old 09-27-2007, 02:12 AM   #76 (permalink)
Ignacio
I just installed the Spacer and Gasket and now when i try to put the car into reverse it feels weird. Does anyone know what this is and how to fix it?
Old 09-27-2007, 06:54 AM   #77 (permalink)
DakidzSi's Avatar
George
Mine were the same. That shouldn't affect performance LOL!
DakidzSi is offline
Old 09-27-2007, 02:05 PM   #78 (permalink)
i'm pretty sure it has nothing to do with the spacer...
Old 09-27-2007, 02:13 PM   #79 (permalink)
Ozzie
yes, i installed it but will look to replace the plastic plug with a metal one soon.
ozfizzle is offline
Old 09-27-2007, 02:22 PM   #80 (permalink)
Ozzie
so i sprayed the brake cleaner all around the throttle body and my car did not idle at all. do you have any other suggestions.
ozfizzle is offline
Closed Thread
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/53070-diy-p2r-tb-spacer-gaskets.html
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-15-2008 11:57 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-03-2008 09:24 AM
F.S: P2R K20 Throttle Body Spacer - Florida Honda Crew This thread Refback 12-27-2007 11:42 PM
P2R Power Package: Intake Manifold Gasket, TB Gasket and TB Spacer Excelerate Excelerate Performance 180 12-01-2008 11:39 PM
Cheapest Prices where (dcrh and P2R spacer) ryanster01 Bolt-Ons And All-Motor 13 08-13-2007 05:48 PM
p2r spacer... rkalloo Mechanical Problems & Technical Chat 0 07-12-2007 12:35 AM
Injen CAI + P2R TB Spacer Question NewYorkJon Bolt-Ons And All-Motor 4 06-24-2007 10:53 AM
