Dan the DIME slayer
DRL's Daytime Running Lights...
does anyone know the easiest and most simple way to reach and change the DRL's?!...does anyone know the model of the DRL bulbs as well?...so much **** is mashed into the hoods of these civics its impossible to change anything without dismantling the whole front end!...also if there is a DIY article on this with pics, a link would be helpful too, thanks!
Greg
I changed my low beams by taking the battery and coolant overflow out for the drivers side (easiest way) and through the wheel well for the passenger side. You can also go through wheel well for drivers side but I found it more difficult (be sure to turn the wheel all the way).
Dan the DIME slayer
you have to reset the radio code and all when you remove the battery right?...if you go thru the wheel well, does the whole wheel well come out? or do you remove some clips and bend it back?
#6 (permalink) | |
![]() Join Date: May 2006
J. M. back by popular demand!
http://i61.photobucket.com/albums/h52/jbpray/cali-1.jpg Visit my city! Free vagin for every resident (in direct contrast to the other cities that only provide free Fleshlites!) http://eat-mykhram.myminicity.com/ |
#7 (permalink) | |
You'll only die tired
![]() Join Date: Mar 2006
Joe
...thats how I did it....took like 15min
http://img.photobucket.com/albums/v1...res/redleg.jpg Post Whore #2 (Da Deuce) <INJEN> <GREDDY> <P2R><Eibach><DCSports><TSW> |
Dan S.
.... I change bulbs in and out constantly cause I dont know what i want... Had in HID's, then put back to stock.. but changing them is so easy... BTW the DRL's/High Beams are 9005, Low's are 9006..
#11 (permalink) | |
| Dumb Laws | C2i0v0i1c | Water Cooler | 72 | 12-21-2011 07:45 PM |
| Map lights | ethlar | Civic Coupe And Sedan | 30 | 10-02-2011 11:40 PM |
| H.I.D./Fog Lights for 2007 Honda Civic Si Coupe | MarinoKouch | Lighting, H.I.D.'s, & Neon | 12 | 06-04-2008 04:43 AM |
| has anyone changed their drl lights? | datbacker59 | Lighting, H.I.D.'s, & Neon | 22 | 07-09-2007 07:50 PM |
| Daytime running lights | 8Renovatio8 | Lighting, H.I.D.'s, & Neon | 9 | 11-30-2006 12:16 AM |
