If it's making a very faint click, then yeah, it's normal. I had a Honda technician assure me this last summer when I bought the newer generation Civics. We went from car to car in the lot and sure enough, each clutch clicked when I pressed and depressed the clutch.
Check to see if the fuze cover is properly secured under ur dash. Mine was a bit loose and not in the proper position, it seemed to hit the top of the clutch pedal assembly and made a "click", this was also felt in the pedal. After i reattched the fuze cover correctly problem was gone.
I don't think it has anything to do with cruise control. If you were to set cruise control and lightly rest your foot on the clutch (as a test!!!), the cruise control will shut off immediately. In other words, the clutch is really sensitive and will cancel the cruise control.
| Clutch pedal squeaking | TJ06CivicLX | Mechanical Problems & Technical Chat | 23 | 09-29-2008 03:26 PM |
| Stage 3 Clutch Problem -Help- | SC06SI4U2NV | Forced Induction And Nitrous | 28 | 07-04-2007 11:47 AM |
| Clutch engaging late | JZCivic | Mechanical Problems & Technical Chat | 4 | 06-21-2007 03:08 PM |
| Sound when I press the brake pedal too hard. | y3llo | Suspension and Brakes | 5 | 03-08-2007 06:12 PM |
