Old 08-04-2007, 06:42 PM   #1 (permalink)
For better engine response..
Clean your maf sensor! I've seen it mentioned a few times before on the forum, especially concerning the injen cai.
I finally got a CEL with my injen after a year. I reset it twice but it kept coming back within a day.
I cleaned my air filter with a kit and then sprayed down the maf sensor with some electrical cleaner and all i have to say is WOW at the difference.
maybe it's just my imagination, but i swear the car idles better, shifts easier, less throttle lag, less burpy acceleration at times! one thing is for sure though, it got rid of the cel...
just letting people know!
taejinah is offline
Old 08-04-2007, 06:43 PM   #2 (permalink)
Go Gators!
Firestrife's Avatar
Keenan
maybe just cleaning the filter helped a lot. I mean both are very good things to clean but most likely a clean air filter makes worlds of difference.
Firestrife is offline
Old 08-04-2007, 06:56 PM   #3 (permalink)
Its always a good idea to clean the throttle body (and MAF, etc..,) periodically. If you ever take the intake tube from the throttle body and open the butterfly, you'll see what I mean...lot's of varnish and carbon buildup. Just be sure you use air intake and throttle body cleaner, NOT carb cleaner. use a toothbrush and get up in there. Be forewarned though that all that shit will run down the intake and your car will 1)be tough to start, and 2)will belch white smoke for 10-20 seconds while it burns out the cleaner.
I've found its better on starting if you've wedged the butterfly open for a hour or so and let the cleaner try and evaporate from the intake tract.
S Eye is offline
Old 08-04-2007, 07:07 PM   #4 (permalink)
pd0019's Avatar
what electrical cleaner did you use?
pd0019 is offline
Old 08-04-2007, 07:33 PM   #5 (permalink)
nice. good call. i'll try that next time i get around to cleaning the filter/maf.
i just used a CRC brand, i think every autozone or checkers etc has em. it's called electrical component cleaner or something. u don't do any rubbing cuz it will damage the very fragile maf sensor. u just spray at it (and it will evaporate in seconds also).
taejinah is offline
Old 08-04-2007, 08:30 PM   #6 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
Makes sense!
si_civic is offline
Old 08-05-2007, 02:11 AM   #7 (permalink)
Mateen's Avatar
How about a DIY?
Mateen is offline
Old 08-05-2007, 04:26 AM   #8 (permalink)
^ Yeah that.
Can you take some pics, cause I have no idea what the maf sensor is
dextor is offline
Old 08-05-2007, 05:43 AM   #9 (permalink)
Jardiniboy's Avatar
Jasten
Originally Posted by dextor
^ Yeah that.
The maf sensor is connected to the intake system to measure how much air is flowing through the engine so the ECU can determine how much fuel to add.
Jardiniboy is offline
Old 08-05-2007, 11:02 AM   #10 (permalink)
Go Gators!
Firestrife's Avatar
Keenan
it shouldnt be that hard guys 2 screws (i think) pop it out and spray some cleaner let dry a bit then pop it in.
Old 08-05-2007, 02:19 PM   #11 (permalink)
Wakeboarder11's Avatar
Tyler
yup i did this a little bit ago. I picked up some electrical contact cleaner at autozone. If fixed my buddys cel after we sprayed his maf.
Wakeboarder11 is offline
Old 08-05-2007, 02:22 PM   #12 (permalink)
Mateen's Avatar
pics please pretty please.
Mateen is offline
Old 08-05-2007, 02:24 PM   #13 (permalink)
Smiley Whore
SiViC81's Avatar
Shu
Is the cause of the CEL the maf sensor or air filter or is it both?
SiViC81 is offline
Old 08-05-2007, 02:25 PM   #14 (permalink)
Go Gators!
Firestrife's Avatar
Keenan
MAF is where most of the problems start.
and dude Mateen just go out to the car and pop the hood it should be self explanatory.
Old 08-05-2007, 02:48 PM   #15 (permalink)
PhotobucketDragon Slayer
I had a CEL on my EX for months after I installed an Injen CAI. I couldn't figure out what was causing it, but now I have a feeling that all I had to do was clean the MAF sensor. I might have got grease or dust on it during the install. I even took it out once to look at it, but it looked fine. I got so tired of looking at the stupid CEL I decided it was time trade for an Si.
Silver8th is offline
Old 08-05-2007, 02:50 PM   #16 (permalink)
Smiley Whore
SiViC81's Avatar
Shu
^^good reason to upgrade to Si
SiViC81 is offline
Old 08-06-2007, 10:50 PM   #17 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
How on Earth does one clean a MILF ?
CRC makes a good MAF sensor cleaner
http://www.amazon.com/CRC-Mass-Flow-.../dp/B000EGH57G
si_civic is offline
Old 08-11-2007, 01:12 PM   #18 (permalink)
Robare's Avatar
you first (un)-screw her(2 phillips)...then you 'pull out' the plug (electrical connection)...then you spray it all over her (maf electrical sensors)
Robare is offline
Old 08-11-2007, 11:45 PM   #19 (permalink)
Mateen's Avatar
Apparently some of us (I included) that keep asking the same question over and over, do not know exactly where to look for. A pictur may be? And please do not insult us with your sarcasm.
Mateen is offline
Old 08-12-2007, 12:31 PM   #20 (permalink)
3rd picture:
DIY Air & Cabin Filter Replacement
av911 is offline
2006 Civic Engine: I-VTEC webby Garage 8 10-15-2007 11:54 PM
TSB Engine - Rattle From Right-Front of Vehicle Over Bumps iknowmysh1t Mechanical Problems & Technical Chat 1 06-29-2007 02:25 PM
Kind of interesting - Honda Chronology 1946-2005 webby Water Cooler 4 10-04-2006 09:39 PM
2006 Honda Civic Engine Information webby Garage 4 08-04-2005 01:53 PM
2006 honda world news webby Garage 0 07-25-2005 09:31 AM
