Old 08-02-2007, 09:38 AM   #1 (permalink)
poizun's Avatar
Dan
Hydrolock... maybe?
Now, from what I've read, if an engine ever hydrolocked, it's pretty much screwed and would cease to function, correct?
I ask because I SERIOUSLY was freakin out yesterday after I brought my car into the local brushless carwash. Now, sure it was idle during the wash, but when it was done, I put it into gear to move forward and as I stepped on the gas, my baby stalled on me. So now, I'm like... wtf? For the record, I have a Fujita CAI. I started the car again, which is a BIG nono if it had hydrolocked, upon which it stalled again. So then I'm sweating, left the car off for a bit and, paced back and forth for a while panicking. After a few minutes, when all hope was lost, I tried starting again, which, again, is bad if it was hydrolocked, but it started this time. Then I drove home (staying as low on the tach as possible) and prayed that she'll start again the next day.
So. My question is. Is it still possible to have done damage to the engine and still have it function alright? Mind you, there was no CEL or anything like that indicated... TIA for any replies.
poizun is offline
Old 08-02-2007, 09:46 AM   #2 (permalink)
Scrodums
Yodums's Avatar
Hiro Nakamura
You just got some water on the filter and it sucked it in. Not really a big deal. Now, if you were to fully submerge the filter and you applied the throttle...
Yodums is offline
Old 08-02-2007, 09:53 AM   #3 (permalink)
GlxyGry06Si's Avatar
your fine. the filter was just wet. when it stalls let it sit for 30 minutes before trying to start it next time. you will definatly know when you have hydrolocked your motor. just be careful going thru the car washes.
GlxyGry06Si is offline
Old 08-02-2007, 09:56 AM   #4 (permalink)
Tuna Fiddle™
twistedframe's Avatar
Dave
Ok so I doubt you actually hydro locked if your car ran again. Also for future reference its better to keep the revs higher since there is less manifold vacuum therefore less risk of sucking up water/ I don't think you have much to worry about since your car drove home w/o throwing a code. I would take the filter off and make sure it is dry and also make sure that there is no standing water still inyour intake tube. Other than thats theres not too much you can do. Good luck
Originally Posted by Gonzo View Post
if I found out I was pregnant at 16 I think I'd be flipping the *#&% out.
jed = hermaphrodite
twistedframe is offline
Old 08-02-2007, 10:45 AM   #5 (permalink)
poizun's Avatar
Dan
Thanks for the reassurance guys. Your expertise is very comforting
Time to put on that hydroshield........
poizun is offline
Old 08-02-2007, 11:56 AM   #6 (permalink)
tommyroo's Avatar
Undercarriage wash FTL.
tommyroo is offline
Old 08-02-2007, 12:04 PM   #7 (permalink)
inyong1988's Avatar
Junction Produce
drove during heavy rain,,, and took it to car wash every 2 times a week. im fine with my injen cAI.
inyong1988 is offline
How does hydrolock work? Why? Answer is here. KingMarineM16a4 Bolt-Ons And All-Motor 28 07-20-2007 07:46 AM
HYDROLOCK!!! no but ALMOST! O6 Si Driving Experience 28 07-19-2007 10:12 PM
Hydrolock cost somedaySI Bolt-Ons And All-Motor 28 04-04-2007 03:50 PM
injen cold air hydrolock??? k20beast Bolt-Ons And All-Motor 1 02-27-2007 05:09 PM
Truth on HYDROLOCK SlimChucks Bolt-Ons And All-Motor 10 01-28-2007 02:04 PM
