First oil change for an 06 Civic?
We just got a new 2006 civic ex sedan today!
![]() I've heard that new cars use a special kind of synthetic oil to help break in the engine but at what point should I have it changed? The dealer said that the car's maintence minder will tell me when it needs to be done... I wasn't exactly comfortable with that answer though its probably the right one. |
Tuna Fiddle
![]() Join Date: Jan 2006
Dave
i believe you want to wait until the 1st scheduled oil change to ...do an oil change. ( i think the owners maual recomends 3000 miles) i know that sounds stupid but they use a special kind of oil from the factory that helps the motor break in. if you change it to synthetic too soon the rings will not seat properly and you will have major oil consumption issues down the road.
Tuna Fiddle
Dave
alot of old time techs say that b/c for a long time they wanted you to leave that "break in" oil in for a pretty long time, but now with the technology they have come up with in oils and assembly lube i think 3000 is plenty. i think the owners manual even says 3000, but i'll check i may be wrong.
#6 (permalink) | |
hmmm.... i just over 6000kms and mine just hit 30% |
Thats another good question... does it alert you when you need to change the oil or do I just have to periodically check the percentage on the dash? At what % should you change it?
(This is probably where it helps to rtfm) |
I did mine at the recommended 5,000 miles, my oil life indicator was at 50% at that point. The techs didn't say anything on if I should wait longer or what, and I was in and out in 30 minutes.
Crazy Yellow Puppet
![]() Join Date: Feb 2006
Back and Forth Forever
I think it really depends on how long you want to keep your car and how well you want to maintain it/how much money you're willing to spend. If you really don't care and will sell it in the next few years, then change the oil when it hits 15%. If you want to keep it and hand it down to your kids or whatever, change it every 5000 miles as the manual says. Personally, I change it every 5000 miles, regardless of what the oil indicator says.
#10 (permalink) | |
Everything that I have read says to follow the Maintenence Minder. |
#13 (permalink) | |
STIG: a tamed race driver
![]() Join Date: Sep 2005
I did that for the first oil change, I think it was around 5000 miles, never agian will I let the oil go that long. It was super black and smelled of sulfur (which is horrible for oil). The special break in oil is not synbthetic, it just has a high moly count to help harden and smooth the metal. In fact in the manual it used to say (in my old '03 it did anyway) not to use synthetic oil until the third oil change. Here is an interesting tid bit, if you want to change that oil out early, use Valvoline Max Life as the replacement. It sounds wierd, but it has a 5 wt% moly content, is 22% synthetic and overall a very well made oil. Don't bother with other high milage oils, most are junk. I use this oil around 60,000 miles. The oil meter is simply a mathatical formula that find the stress put on the oil and tells you how much life you have, it is in no way measuring the actual oil in your car. If your drive agresively, always shifting at higher RPMS, this will kill your oil faster, the meter takes this into account and tries to figure out when the oil is "dead." The problem is that this type of calculation is different for every oil, so if you are not using honda oil, this may not be true. Synthetic will probably last long than the indicator says, and cheaper Wal-mart oil will be long gone before the oil indicator says, so don't tak ethis thing as the tell all for oil, it si just a guide. |
#14 (permalink) | |
Sorry, I forget what size it was but that sounds about right, I just remember it was larger then my F150 with a 5.4L engine, thought that was funny. |
#15 (permalink) | |
they're going to prove to you how you should change your oil x amount of miles by copying and paste some article they found somewhere by some nutcase or oil manufacturer trying to sell you their oil. |
#16 (permalink) | |
I am an engineer, working on my PhD. Chemical engineer actually, you know the ones that distil and make gasoline and oil... I actually know a few of the engineers at Honda too, they told me that thing is only a guide, as always if you want to how much life is in your oil, get it tested. |
#17 (permalink) |
i trust the engineers that work at honda than any kid on this forum any day even if the kid "knoweverythingthereistoknow" about cars & life.
but i guess the kid who can paste the most baseless & useless info about oil knows better than the engineers who build some of the most reliable & efficient motors in the world. i'll stick with what honda saids "change oil once it reach 15% on the maint. system, if not, once a year" |
#19 (permalink) | |
chemical engineer still in college with vast resources to test and study >>>>>>> those dumbass 70 year old japanese engineers who's been working/testing at honda's their entire life and been making some of the most reliable engine in the world |
#20 (permalink) | |
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/5059-first-oil-change-06-civic.html
| First oil change for an 06 Civic? - 8th Generation Honda Civic Forum | This thread | Refback | 12-22-2007 01:20 PM | |
| 2006 Civic Chassis Codes | 2fast4u2 | Dealership Experience | 45 | 04-12-2011 02:32 AM |
| On The Track - 2006 Honda Civic - 8th Generation Civic 2006 Honda | webby | Honda Industry News | 6 | 08-27-2009 05:35 PM |
| Civic SI Sedan Comes To America - Chicago Auto Show Debut | webby | Honda Industry News | 11 | 04-19-2008 10:24 PM |
| 2006 honda civic lineup pricing released | webby | Honda Industry News | 11 | 07-04-2006 07:12 AM |
| 2006 Civic Summary from Temple of VTEC | shoptb | Dealership Experience | 4 | 01-11-2006 03:40 AM |
