Old 07-30-2007, 12:33 PM   #1 (permalink)
Headlight Problem
Hi,
A body shop recently replaced the driver's side front headlight assembly after my Civic ('06 EX coupe) was hit while parked. Last week, I noticed that the sidemarker isn't working on the front driver's side when the headlights are on. The turn signal, however, is working properly.
Could the body shop have wired the headlight assembly incorrectly, or could the bulb need to be replaced?
If you think it might be the wiring, I would appreciate quick instructions on fixing the problem so I don't have to bring the car back to the shop.
Thanks for the help!
-Dan
dkatz is offline   Reply With Quote
Old 07-30-2007, 12:49 PM   #2 (permalink)
Ur soul. I haz it.
jasonandre's Avatar
Disciple of Discord
Well....have you already tried replacing the bulb to rule that out?
Originally Posted by Special Ringpop View Post
Your ass isn't typically a reliable source.
Hey, people get on my case for being a Godless Atheist Butt-Pirate, but I try to be objective.
jasonandre is offline   Reply With Quote
Old 07-30-2007, 12:53 PM   #3 (permalink)
NIGHTHAWKSI's Avatar
Ian
he said the turn signal works which is the same bulb as the side marker...so that is ruled out.
to the OP...try the fuse...if that is not it, its proboyl a wiring problem. sounds like the body shop didnt realize that the harness was damaged. there is not much that can be messed up since all the harness does is plug in....the body shop probobly should replace the healight hanress and go from there....
NIGHTHAWKSI is online now   Reply With Quote
Old 07-30-2007, 12:59 PM   #4 (permalink)
Ur soul. I haz it.
jasonandre's Avatar
Disciple of Discord
jasonandre =
Old 07-30-2007, 08:01 PM   #5 (permalink)
Which fuse # controls the side marker/turn signal? The manual does not list any specific fuse for the side marker, so I am wondering what it would be grouped together with...
Old 07-31-2007, 09:17 AM   #6 (permalink)
Ian
it might not have its own fuse...probobly with either the headlight/turn signal/parking light fuse...
Old 07-31-2007, 10:53 AM   #7 (permalink)
n00b retro whore
ethlar's Avatar
The bulb may work as the turn signal but its a dual fillament bulb, so the side marker filament could be out. so dont rule the bulb out till you actually check it and maybe swap it to the other side of the car
Old 07-31-2007, 10:55 AM   #8 (permalink)
Ian
^very good point...forgot about that.
+1
You must spread some Reputation around before giving it to ethlar again.
Old 07-31-2007, 11:54 AM   #9 (permalink)
awashko's Avatar
Adam
Exactly my thoughts...
awashko is offline   Reply With Quote
Old 07-31-2007, 12:17 PM   #10 (permalink)
That's a really good point. I will swap the bulbs when i get home from work and see if that is the issue.
DIY: TSX projector retrofit 2 hoanger Lighting, H.I.D.'s, & Neon 12 11-20-2008 03:07 AM
Window Problem waross Mechanical Problems & Technical Chat 14 12-17-2007 05:27 PM
headlight questions hashbrownn Lighting, H.I.D.'s, & Neon 10 05-13-2007 10:58 AM
Problem with Pioneer P880PRS install nuked99 I.C.E., Electrical, Security, & Navigation 2 11-13-2006 12:24 AM
Just got back from Autozone and was looking at blue headlight bulbs! Civic Pride Inside and Out 6 10-28-2006 10:07 AM
