using different oil filter
I've done it on a Jeep before...but this isn't a jeep lol
I have a lot of the old Honda filters. they are bigger and wider than the ones that are used today(ph3593A fram #) The new ones, which they have changed over for quite some time is skinnier and smaller. but they both fit in the screw hole. honda/hyundai have used them in their vehicles(that I know of) so Im guessing it is ok to use the bigger filter? I'm not looking for better performance...I'm just looking NOT to spend money on the smaller filter when i have 30 of the bigger OEM honda filters sitting around |
I've used larger filters on my past cars (all domestic). Although this is my first Honda, I don't see where using the larger filter would cause a problem as long as the following criteria are met:
1. The threads are the same 2. The gasket on the filter meets the mounting plate on the block in the appropriate place. 3. Larger filter = more oil needed, don't forget to check to be sure your oil level is up in the safe zone. |
#4 (permalink) | |
i wonder why they went with the smaller design... my parents MDX uses the same small one even tho the car is 3.5L.... wonder why |
| K&N filter...wow! | 954K20_SI | Bolt-Ons And All-Motor | 66 | 05-14-2008 06:44 PM |
| Oil Filters | leez2273 | Garage | 16 | 06-08-2007 09:20 PM |
| FYI '06 Si owners - Early oil consumption | Janizary | Civic SI | 38 | 08-19-2006 01:18 AM |
| Oil Changes... | cazzerz | Civic Coupe And Sedan | 26 | 04-25-2006 05:45 PM |
