Civic EX airbag light reset?? - 8th Generation Honda Civic Forum
Old 09-21-2014, 12:02 AM   #1 (permalink)
soleobjective's Avatar
Kyle
i removed the seats on my '07 EX to do a deep cleaning with a steam carpet cleaner. Before undoing the sensors underneath the seats, I disconnected the negative terminal on the battery. After I finished cleaning the car, I reconnected the sensors to the seats and reconnected the battery. Now when I start the car I get the red airbag light (with the exploding airbag picture).
How do I reset this?? Tried disconnecting the negative terminal and reconnecting after a few mins. I was gonna try the paperclip trick, but my sensor looks a little different from the one in the YouTube video. My yellow sensor clip has 4 connectors and the one in the video only has 2.
Anyone every cleared this on a non-Si? Any ideas on how to get rid of this? It seems simple enough to do without going and getting overcharged by a dealership.
soleobjective is offline
Old 09-21-2014, 01:34 AM   #2 (permalink)
BlurpleFG1's Avatar
Zimmer
Some of the 07 models had bad crimping on a connector under the passenger seat, check out tsb 10-001.
BlurpleFG1 is online now   Reply With Quote Quick reply to this message
Old 09-21-2014, 08:31 AM   #3 (permalink)
Does this do anything?
leveldowen's Avatar
Scott
You're not using a paperclip on the actual airbag connector at the seat, you're using it on the two pin diagnostic connector that is plugged into a dummy slot on the MICU (under-dash fuse box).
You should by all means have the code read and have the system inspected before clearing it though, it could save your life.
leveldowen is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
reset the airbag light with hondata flashpro? cpac97 Hondata 14 04-28-2012 05:17 AM
Airbag light, FD1 06 civic trevs ek9 Mechanical Problems & Technical Chat 0 03-07-2012 09:04 AM
Airbag light reset near Silver Spring? simsima325 Mid-Atlantic 0 03-07-2011 12:35 PM
I need to reset my Airbag sensors, but Honda says its $45 to do so... how can I do it bikinpunk Mechanical Problems & Technical Chat 4 05-23-2008 06:02 PM
Crashed Si, airbag light ON, no airbag poped out...PICS noumen_arete Mechanical Problems & Technical Chat 7 05-29-2007 08:49 PM
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
