#8 (permalink) | |
its not going to hurt your engine really, they say 100k for a reason, i'm sure they know what there doing. either way if you do change them out, are your upgrading them? |
Kill Your Self Krew
air filter every 10k. i hate to see yours at 30k.
#10 (permalink) |
like suggested, read your manual. the reason Honda includes an OWNER'S manual is so the OWNER will read it and be informed about the car.
but here is what you should check/have checked out. 1. Spark Plugs (don't leave it until 100k) 2. Brakes 3. Tires 4. Any type of fluid |
#11 (permalink) | |
really? but it has a seperate warranty as a no tune up until 100k gaurantee? |
#13 (permalink) | |
Even thought the plugs may technically last that long, if they are starting to wear and produce even slightly less efficient spark at say 50,000 miles it is not that expensive and probably worth it to change them rather than run slightly less efficient plugs for another 50,000 miles. Also, when you have dissimilar metals (iron spark plug in aluminum head for example) corrosion is worse. I have seen a few cases where a spark plug left in a head for 100,000 miles damaged the aluminum threads of the head when being taken out. With platinum plugs the gap may stay withing specs for that long, but for the cost and time to change them I would never take the chance. I would never let plugs go longer than 50,000 (I usually end up changing them a little sonner, 30-40K or so). |
#14 (permalink) | |
#15 (permalink) | |
| THE OIL FAQ - synthetics, intervals, weights, brands | jdrumstik | Mechanical Problems & Technical Chat | 98 | 10-16-2008 01:53 PM |
| How many miles do you put on your SI weekly? | Nighthawk07 | Civic SI | 53 | 02-06-2007 11:15 PM |
| car meet in springfield? | fhound258 | North-East | 42 | 07-31-2006 12:20 AM |
| Anyone got a carfax account? | Kabs | Water Cooler | 15 | 12-23-2005 01:02 AM |
| 1 more month!!! | Ep3racer954 | Garage | 14 | 11-01-2005 10:53 PM |
