alignment problem, pulling to the right
im taking my car into the stealership under warrenty for them to check/realign my car, my car pulls to the right, but i have to correct it with the steering wheel, so its basically of center, just wanted to get your opinions on it and if u guys think its just an alignment problem, also if any of you have experienced this before and what had to be done to fix it, along with any service bullitens that might be to my help, basically anything thatll help me out
thanks guys i take the car in on thursday, its an 07 Si btw.. |
I got my car in april 06, I now have 14K on the car, 3 alignments later from the dealership and the car still pulls to the right.
LX sedan by the way. 200 miles after I got the car, they did the first alignment. After the third attempt, I gave up and learned to live with it. |
#3 (permalink) | |
#5 (permalink) | |
Someone just posted the TSB again in this section that they use for accords and other hondas with pulling to the right. I feel it's a design flaw and if they do fix it, they are going to have to change something else to correct it and then something else will pop up as a result. |
actually, they are.. all roads are tilted to the right in the right lane, and tilted to the left in the left lane, this is for when there is water on the road.. everybody who is having problems with it pulling to the right, drive in the left lane and you will see your problem will get better, but of course im not saying that there isnt a problem, im sure there is..
| "Clutch" Squeak problem found.. | Lobos8403 | Mechanical Problems & Technical Chat | 37 | 01-14-2008 10:51 PM |
| Service Manual Alignment Specs? | Goose | Suspension and Brakes | 8 | 12-08-2006 06:18 PM |
| Alignment Problem | nnorton | Mechanical Problems & Technical Chat | 5 | 11-01-2006 02:18 PM |
| '07 Si alignment procedure Problem??? | pennRON | Civic SI | 9 | 10-29-2006 09:18 PM |
| Wheel Alingment Problem | trogers8 | Mechanical Problems & Technical Chat | 0 | 06-11-2006 08:13 PM |
