LinkBack (9) Thread Tools Display Modes
Old 01-12-2008, 12:36 AM   #201 (permalink)
Grab her face
k20z3 Koop's Avatar
Keith
Originally Posted by Special Ringpop View Post
I don't care if they updated it or not. The bullitin I have says all 2006 coupe models.
You can bet I'm going to raise hell if they say they aren't going to do it. If Honda put it out, clearly there was a reason for it.
Man oh man I have never seen a car company handle TSBs and recalls as poorly as Honda. I swear to God I'm furious about this.
If there isn't a fix for third gear pretty soon, I'm selling the car. I've had it with how Honda has treated me with this. For every recall and TSB, I have had to find it online and pretty much beg them to do it with downloaded proof.
If it weren't for this site, none of the recalls or TSBs would be done, because they loooove to tell me "There are none listed for your car" everytime I'm in there. I've had it.
That sucks man... Sounds like your dealership is junk. Mine did the TSB for the bump stop (which fixed it BTW) even though my car was out of the VIN range... I didn't even bring it up, I told them about the popping, sat in the waiting room for a few and they told me they were replacing my bump stop.
k20z3 Koop is offline   Reply With Quote
Old 01-16-2008, 09:02 PM   #202 (permalink)
I got a mangina!
"Ridge"Racer's Avatar
Justin
so get this, i put in my new tokico struts and eibach springs, and instead of using the new bumpstops i bought online, i was lazy and used the old ones! now the popping sound is still there. however, would there have to be pressure on the bumpstop for it to bind? just because i lowered my car doesnt mean that now the strut is compressed to the point that its resting on the bumpstop, especially since i cut it. i dont know, im tired of dealing with it and i think im just gonna say f it.
Join the ATL SQAD
"Ridge"Racer is offline   Reply With Quote
Old 01-16-2008, 09:20 PM   #203 (permalink)
Grab her face
k20z3 Koop's Avatar
Keith
it could be binding, or sticking at the top of the damper shaft, then getting fired down when strut is compressed. Hence causing the pop noise when it slides down the shaft and hits the bottom of the strut.
Old 01-16-2008, 11:05 PM   #204 (permalink)
drutoobored's Avatar
andrew
you guys can try this and see if it stops the noise
Clunking And Popping Noise FIXEDD!!!!
drutoobored is offline   Reply With Quote
Old 01-23-2008, 12:55 PM   #205 (permalink)
DOHCKLR's Avatar
EZZZZZZY E
the reason they said that they could not replace it was because the bump stop that was on the recall was not the correct one.. It was not the correct size or even fit into the hole...
My car only make the popping noise when i turn right when it is like 9degrees outside.. so i am not to worried about it
DOHCKLR is offline   Reply With Quote
Old 03-18-2008, 12:24 AM   #206 (permalink)
Solution
I Have An 2007 Civic Si Sedan And I Had The Same Problem After I Installed My Tein S-techs, At First I Thought It Was The Bearing Hub Assembly. It Was The Bump Stops, I Called Tein Myself And They Told Me That It Needs To Be Cut At Least 1" Inch Or The First Loop On The Bump Stop. You Will Need To Remove The Whole Springs. To Be Able To Get To Them. Hope Tgis Helps!
Thanks Guys
07sicivictx is offline   Reply With Quote
Old 03-28-2008, 02:41 AM   #207 (permalink)
is this thing coverd in 100,000 mile worenty that i bouch i alredy passed 36000 miles
umer8566 is offline   Reply With Quote
Old 04-22-2008, 10:24 PM   #208 (permalink)
Does anyone with the 2008 models have this problem?
samzclub77 is offline   Reply With Quote
Old 04-28-2008, 12:35 PM   #209 (permalink)
i do.. took it back 4-5 times.. last time they changed the bumpstops and the sway bar links and last night i heard it again so today i'mma bring it back again..
joon joon is online now   Reply With Quote
Old 04-28-2008, 06:22 PM   #210 (permalink)
NE Crew Member #67
FG2NME's Avatar
i have like 47,000 miles on the car already but i don't exactly know what to listen for...i'm dropped on sportlines and when i hit a bump i hear a small click but nothing crazy...am i supposed to be doing something or it just sounds like it?
ramon@uncommonk20.com
I mean after all the things that we've been through
I mean after all the things we got into
Hey yo, I know of some things that you ain't told me
Hey yo, I did some things but that's the old me
And now you wanna get me back and you gon' show me
So you walk around like you don't know me
You got a new friend, well I got homies
But in the end it's still so lonely
- Kanye
FG2NME is offline   Reply With Quote
Old 05-05-2008, 12:32 AM   #211 (permalink)
I have an 08 sedan and its been doing it since i drove out the dealers lot. I have taken it three times and they have told me they cant find the problem. Bunch of lazy bastards.
ldazzzz is offline   Reply With Quote
Old 05-05-2008, 12:45 AM   #212 (permalink)
'08 Civic Si
My 2008 does it all the time. The dealer say because there is no TSB for my model they won't even try changing the bump stops. Oh well, it's just noise and this car makes all kinds of noise. At least it's not going to fall apart.
rob76 is offline   Reply With Quote
Old 05-05-2008, 05:32 PM   #213 (permalink)
Is yours a coupe or sedan.
Old 05-05-2008, 07:02 PM   #214 (permalink)
Dave
I've got an '08 and I get a small "pop" from the left front strut once in a while usually in a parking lot or when turning right on a street that has a deeper than average gutter which places more force across the sway bar. If the noise is just the bump stop I'm not going to worry about it. I thought it might have been how the spring coils stack and rub. Doesn't seem to be a big deal and as long as it's not going to tear something up early I'd rather leave it than try to have Honda tear it down. The closest dealer is about 100 miles from home for me.
OrdnanceMarine is offline   Reply With Quote
Old 05-05-2008, 09:19 PM   #215 (permalink)
'08 Civic Si
Mine's a sedan
Old 05-06-2008, 05:12 AM   #216 (permalink)
michinsi's Avatar
Tom
No 07 si sedans? I had this problem but it seems fine now. Haven't heard the bump for 5000+ miles.
michinsi is offline   Reply With Quote
Old 06-27-2008, 07:32 PM   #217 (permalink)
Anybody else with an '08 SI sedan that has this problem?
I hear the popping noise in the driver's side front quarter area when going over bumps at slow speed and turning simultaneously. Service department could not replicate. I can't believe '08s would be affected by this. Anybody else have this problem too? I'll ask them to take another look next time I take it in for service. All in all, I've had the car for 2 months now and will never buy another Honda due to the many other quality issues I've had. Canada is becoming the new Detroit for quality.
ichor0416@hotmail.com is offline   Reply With Quote
Old 06-29-2008, 12:55 AM   #218 (permalink)
08blk4drsi's Avatar
Chris
I have this problem also, mine has gotten to where i can hear it while im on a flat surface not making a turn at all, i need them 2 look at my cv joint
08blk4drsi is offline   Reply With Quote
Old 08-04-2008, 09:55 PM   #219 (permalink)
I have the same problem in my 07 civic ex coupe. I took it to the Stealership and they told me they couldn't replicate the problem. I came back to the dealership with TSB in hand and demanded that I take a ride with a tech so that he can here it. First turn he takes it happens, then 2nd turn it happens, so on and so on. It happened like 10 times durning a 5 minute ride. They put the car on the lift again and then came out and told me that they are going to do the TSB (since i had it in my hand) and that they are also going to do a drivers side strut mount. Hopefully this fixes it because i am sick of fighting with the dealership to get my car fixed.
UPDATE: Got my car back from the dealer and the problem is fixed with TSB 07-043. No more popping or clunking noises. All of it was covered under warranty.
mikez is offline   Reply With Quote
Old 08-21-2008, 10:13 PM   #220 (permalink)
magpilot's Avatar
My 07 FG2 had this problem and now my 08 FA5 has it. I'm going to make an appointment next week and let you all know what happens.
magpilot is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/48734-popping-front-suspension-solved-tsb.html
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: 2007 Civic Si Sedan Front Suspension Issue This thread Refback 02-27-2008 07:29 PM
Transportation archive at The Blog of Angelo This thread Refback 01-22-2008 07:52 PM
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: 2007 Civic Si Sedan Front Suspension Issue This thread Refback 12-20-2007 03:18 PM
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: 2007 Civic Si Sedan Front Suspension Issue This thread Refback 12-20-2007 03:09 PM
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: 2007 Civic Si Sedan Front Suspension Issue This thread Refback 12-17-2007 01:29 PM
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: 2007 Civic Si Sedan Front Suspension Issue This thread Refback 12-12-2007 05:04 PM
Mechanical Problems & Technical Chat - Page 49 - 8th Generation Honda Civic Forum This thread Refback 12-11-2007 08:26 PM
2007 Civic Si Sedan Clicky Knock Popping Noise While Turning in Front Suspension at The Blog of Angelo This thread Refback 12-07-2007 12:18 AM
2007 Civic Si Sedan - OH YEA! at The Blog of Angelo This thread Refback 12-06-2007 02:23 AM
Si Front & Rear Sways on an EX Sedan iVTEC Suspension and Brakes 231 09-15-2008 05:21 PM
popping sound from right front(passenger side) sickyute Suspension and Brakes 14 11-24-2007 07:19 AM
My Official Suspension Upgrade Info and Pics Thread Cookstar Suspension and Brakes 69 09-27-2007 11:38 PM
A popping sound from front passenger when turning wheel. SonicK20Z Mechanical Problems & Technical Chat 20 03-13-2007 11:53 AM
Non-Si lowering springs CoryB CorSport 8 07-20-2006 03:07 AM
