Old 07-17-2007, 03:29 PM   #1 (permalink)
rpm trouble
ok I have 96 civic ex with a 96 civic dx motor in it since we put the motor in it redlines at 5500 rpms and my question is why would it do that wen its suppose to be redlining at like 7. I would realy apreciate the help thanks.
civic_club_07 is offline   Reply With Quote
Old 07-17-2007, 04:44 PM   #2 (permalink)
BigT's Avatar
Just a shot in the dark since I have very little info, but is it manual or automatic? Either way, there should be something (PRNDL switch in auto, neutral switch on manual) which tells the computer if it is in gear or in neutral. Many ECU's set the rev limiter lower when free-revving. If this did not get hooked up properly (or at all) it could cause this problem.
Any more information about this engine switch? More info would be helpful.
BigT is offline   Reply With Quote
Old 07-18-2007, 01:17 PM   #3 (permalink)
slostjoe's Avatar
Skyler
Yes check all the connections on the ECU and are you in gear when this is occouring.
slostjoe is offline   Reply With Quote
Old 07-18-2007, 01:18 PM   #4 (permalink)
NIGHTHAWKSI's Avatar
Ian
this is a much better question for the guys at honda tech...
NIGHTHAWKSI is online now   Reply With Quote
Old 07-18-2007, 01:32 PM   #5 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
Yeah, Honda-tech.com will have a lot of knowledgeable better there that can give you a better answer about swaps and what not.
K20Z3 Turbocharger Analysis DetachmentBravo Forced Induction And Nitrous 42 07-05-2008 02:24 PM
K-series experts check in please. firmhonda Garage 35 09-27-2007 01:22 PM
All vtecs are not created equal GeezerSi Water Cooler 3 06-18-2007 07:47 PM
RPM &Temp Mateen Civic Coupe And Sedan 13 11-29-2006 07:53 PM
Best Cruise RPM for fuel economy? NeverNZ Civic Coupe And Sedan 36 07-30-2006 01:19 PM
