Whiny noise in 1st gear
Whenever I am coasting with my clutched pressed and my shifter in first (such as when I'm slowing down to a stoplight), I hear a whining noise coming from either the engine or tranny, I can't really tell. The whine is higher pitched the faster I go, and fades away when I'm fully stopped. Is this a normal sound?
Acorns!
Sounds like like your car is winding down to a stop. If you have your clutch pressed in though - your rpms should drop immediatly so your rpms shouldn't be up. I'd advise against just keeping your clutch pressed in while coasting to a stop. You only need to depress your clutch from like 10mph or less down.
This is my first manual tranny car, so I don't know if I'm developing the right best driving habits. I always put the shifter into first gear like 2 or 3 seconds before a complete stop. Otherwise I am coasting in neutral, but my clutch is still pressed. Is it better habit to let go of the clutch in neutral, and only press it again when I move to first? That's double clutching right? Also, is the winding noise normal?
Acorns!
yes- clutch in, put it in neutral, clutch out - coast in neutral is fine without clutch - brake to a stop if you want. You can sit stopped without the clutch in till the light changes or whatever. Light turns green - clutch in - 1st gear, release clutch with gas -start going.
winding - is going to be normal. I'm guessing you are just hearing the engine whine. |
#8 (permalink) | |
Tuna Fiddle™
good info, also if you just sit with the clutch depressed all the time you are going to wear out your throwout bearing very quickly.
For Sale Forum Rules READ THEM!
#9 (permalink) | |
Acorns!
double clutching
#10 (permalink) | |
It's much better to not keep the clutch depressed when you don't have to. What you're doing is what is commonly referred to as "riding the clutch." Do liek webby said, just use your brakes to slow you down. You can use the engine to slow you down once in a while, I do sometimes with 2nd, 3rd, and 4th gears, never first though. Slowing with the engine isn't necessarily bad, holding the clutch in all the time is. It wears down the clutch much quicker than it would normally. So keep it out as often as possible and your clutch will last longer.
#11 (permalink) |
holding the clutch all the way in should be fine also. what wears a clutch is the plates rubbing, this only happens when you are engaging and disengaging the clutch. holding the clutch in does however wear on the diaphram-like spring in your clutch. I have had this go bad on my before, the result of which is the clutch will not disengage.
the thing to remember is, the clutch is made to wear out. the only thing you can do is treat it as gently as you can, to get the max number of miles out of it. but don't be afraid of it. clutches are cheap, relatively. |
#12 (permalink) | |
Tuna Fiddle™
right holding it in won;t wear the clutch but it will wear out the throwout bearing and when you have to take the trans apart to replace the throwout bearing you might as well replace the clutch.
#14 (permalink) |
Here is my procedure with my Si. Getting on the off ramp of highway from 75 mph, I down shift to 5th, let the engine slow the car down a bit, then about 50, DS to 4th, 35 DS to 3rd, leave in 3rd until coming to stop light then clutch in, neutral and brake to stop. Foot on the brake, clutch out, when I think the lite is about to turn green, I clutch in and shift to 1st ready to take off. I accelerate as much as posible with the fastest clutch release as possible without jerking or chirping and shift to 2nd at about 25, and use low end torque to shoot for 45, and then shift to 3rd to pass or get up to speed, and even going to VTEC (6k rpm). Shifting to 4th and push a little harder past 70 to 75, then shift to 5th to settle the car for smoother ride, then shift to 6th and cruise control for the long haul at about 78 mph. The point of releasing the clutch as fast as possible, and accelerating appropriately, is to minimize a long dragging engagement of the clutch plates. This IMO minimizes clutch wear.
| 06 Civic EX Sedan-Engine Noise at 1400 RPMs | jwoertz | Civic Coupe And Sedan | 64 | 11-09-2007 08:02 PM |
| Video of noise problem.........help! | LsedanX | Garage | 3 | 02-24-2006 12:59 AM |
| Gear ratios for the DX and LX Coupes | honda93 | Civic Coupe And Sedan | 4 | 10-03-2005 10:57 PM |
| Gear ratios for the DX and LX Coupes | honda93 | Civic Coupe And Sedan | 4 | 10-03-2005 10:46 PM |
