Put key in, click click click, no START
Here's the BG of my car.
Bought...5/08/06 15,000 miles on my car. okay, so i tried to start my car this morning and it doesn't start. goes click click click. radio goes on, headlight goes on, car doesn't start. I'm guessing, starter... Well im not a car guy, so i don't know where it is in my car. Car is in park, E brake OFF, and no luck. 1 hour later, gave it another shot, starts off weak, but finally starts. What is this all about... my car is not that old.. the car is STOCK and no mods. |
#6 (permalink) | |
It does that when the battery gets drained completely. I'd left my headlights on one night and did that in the morning.
If you can get it to start, leave it running for about 30 min. Otherwise, jump it with someone else's car and then leave it running. Quote:
#9 (permalink) | |
#10 (permalink) |
Charge your battery. I work at a dealeship and cars do that when they are not dead but don't have enough juice to start. Its normal, our cars with 5-10 miles do that sometimes when they take them on test drives and leave something on.. basically jump it, let it run and your set. Also, needles on the dash usually jump like crazy but since the civic is mostly digital you can't tell :P
#11 (permalink) |
Does your starter register as an acessory that is under warranty in your car? I did not purchase any addition warranty when i bought my car, therefore I am not entirely sure if it covers it or not. If my warranty doesn't cover the starter, how much would it cost me to get this fixed?
My car started an hour, yesterday after the clicking noise, but this morning it almost did it again, while I was at the bank. thanks for all your answers guys. |
#12 (permalink) |
Most likely your starter is fine. As others have said, your battery is most likely bad. A weak battery will cause this exact problem. The battery may have enough power to turn on the lights, radio, etc., but not enough power to run the starter, which takes far more amperage. Unfortunately the battery itself is probably not covered by the warranty.
#14 (permalink) | |
A loose battery connection can cause the starter to not be able to draw the needed amperage, even if the battery is good.
#15 (permalink) | |
Take the battery out of your car, jump in your buddies car, go to AutoZone have them test it. Then you can either know if its the battery, or rule it out. |
#16 (permalink) |
That same thing happend to me about a week ago it took three cranks for it to finally start,idk wtf that was or what caused it. Probably because i heard that the civics have a weak alternator and battery rumored but idk if thats the cause of it not starting.
#18 (permalink) | |
| Ignition problems, key hard to put in | reelbigfish241 | Mechanical Problems & Technical Chat | 4 | 12-18-2006 11:18 AM |
| Programming and Cutting Key Blank | bskouby | Do It Yourself Articles | 3 | 04-06-2006 05:23 PM |
