Treatment
Regardless of the cause, treatment is the same. Removal of the spark plugs will allow access to the combustion chamber. By inserting an irrigation syringe fitted with a flexible plastic tube on the end, you can suck out the liquid that infiltrated the combustion chamber. Once all the fluid is removed, the chamber should be sprayed with a liberal coating of a water displacing lubricant such as WD40[citation needed], and allowed to sit until the remaining water has evaporated. Once the water or coolant has been removed, inspect the combustion chamber for rust. The best option would be to remove the head, but a borescope or small flashlight and mirror will also work. Light surface rust will be normal, but if you see any heavy corrosion, it should be gently removed, and vacuumed out of the chamber. After inspection, pour a tablespoon of assembly lube (such as Marvel Mystery Oil) or clean engine oil into each combustion chamber. Attach a socket to the crankshaft, and slowly rotate the engine through a few revolutions. (Make sure that you turn the engine in the proper direction, see a service manual for proper rotation direction.) If you hear any clanking, or harsh scraping, you should bring the engine to a competent mechanic. After verifying that the remaining systems are free of water (electrical, fuel delivery, air intake, distributor, etc.), re-install the spark plugs and wires, and attempt to start the engine. |
#9 (permalink) | |
#15 (permalink) | |
#16 (permalink) | |
#19 (permalink) |
Location: funny thing about my back is, is its located on my c**k!!
Ryan
i have a 81 cj-5 for my play around vehicle...one day i was cruising along and all of a sudden BOOM...engine locked up no clue what happened....opened hood to find coolent in radiator to be below half way but none had ran out on the ground....so I towed it home and started taking parts off....I started with the water pump and to my surprise the thing would not even turn....when pulled off a bunch of fragments fell off the motor and I was freaking out....ended up the camshaft bolt that holds the gear in place worked its way loose and punched its way through the water pump housing....that was a sad day.....lost a lot of horsepower from water damage....
| How do I find a good dealership mechanic in Los Angeles? | SeanInLACA | California | 8 | 08-27-2007 07:19 PM |
| Good Mechanic in Bergen County | llckll | North-East | 1 | 07-06-2007 01:27 PM |
| Some One Knows A Good Mechanic...!!!! | Hitman21 | South | 2 | 07-04-2007 09:39 PM |
| Mechanic Reco!! | SPORT injected | Garage | 0 | 05-13-2007 01:14 AM |
| Is your mechanic cheating? | shawn-o | Water Cooler | 3 | 05-20-2006 12:36 AM |
