Old 07-09-2007, 09:51 PM   #1 (permalink)
Unhappy Passenger side panel LOoSE!!!!
Hi you guys, i have a 07 four door si and my problem is that panel on the passenger side under the seat belt latch (panel between the front and back door, bottom piece ) keeps popping out and doesn't wanna stay put. it goes back in easily but keeps popping out. i took it to the dealer and they said they didn't find anything wrong and its clearly popping out. I am just frustrated beacuse i only had this car for 5 days and the work quality seems horrible. any suggestions on this would be great. I really dun wanna got to stealership and get the same response again.
JATT is offline   Reply With Quote
Old 07-09-2007, 11:29 PM   #2 (permalink)
Ah, this problem is old and goes back to the 06. I had this problem. You have to pull away the rubber moulding, pull the center bottom panel out and you will see what looks like little tabs. These tabs must be bent back correctly so when you reinstall the rubber moulding, the moulding holds the clips in place. When you see the tabs you will notice that they are bent in a way which does not let the moulding hold the panel snug to the car.
Must easier to do when you see for yourself.
This was posted many many many months ago in this section with photos.
Old 07-10-2007, 01:21 AM   #3 (permalink)
thanks you for your reply that makes sense. i was wondering if i could get the link to that topic or a keyword that i could search. i tried searching but no luck thanks for helping a neewbbb. +1 rep
Old 07-10-2007, 03:30 AM   #4 (permalink)
06CivEXJon's Avatar
Jon
JATT i also have the same problem but its with the passenger side dash panel,it will not pop back into place and i have already took it in to the stealer 3 times. The recent visit the moron service guy said "we also fixed your dash panel" i looked and sure enough it wasn't fixed! then they have the audacity to say on the 2nd trip there one of the service people and the manager said that the ill fitting panels are "normal" i call bullshit on that how the hell is a loose ill fitting poor sloppy fit panel normal??! i swear there is no quality control at the Alliston Ontario Canada plant. HOA has a very serious problem with their dealerships communication and service departments this is very unacceptable its because the stealership is either A. Too lazy to diagnose and fix the problem or B. Wont fix it under warranty because HOA doesn't pay them for compensation or something. check this thread out too Interior Trim Panels Popping Out - Near Seatbelts courtesy of kero. There also is a post from another member on here that made a reply on my thread,and he said his airbag panels on the seats popped off completely! i saw the video and he said that the panels would fall off and hit the floor.
Old 07-10-2007, 07:08 PM   #5 (permalink)
thanks for replying i took out the panel and i did find the clips bent the wrong way so i softly straightened them and popped the panel back in without stripping the weather seal thing. So far so good... but meanwhile driving home i discovered rattling noise coming from under the passenger seat when i go over the uneven area. i got home and started tapping the side of the passenger seat and i hear the noise again. iono what it could be. Since i fixed the panel (HOPEFULLY) the dealer can give me a better answer for this one. and i will let the dealer know how retarded there service department is.
Thanks to all of you that responded and helped a newb out.
Old 07-10-2007, 08:57 PM   #6 (permalink)
06EXJON - thanks for find that post for him
Jatt - My panels have not popped back out, 13K later.
Old 07-10-2007, 09:06 PM   #7 (permalink)
thanks for letting me know. now i just discovered ticking coming from under the passenger side front seat. I narrowed it down to when i bang on the side of the seat i hear the ticking noise. I am not happy about this. DAMMMMMM Its only been six days....... i had high hopes from HONDA
Old 07-10-2007, 09:20 PM   #8 (permalink)
06CivEXJon's Avatar
Jon
No problem man we all help each other out. my interior hasnt had any other panels pop off or loose and im at 10,000 miles but its the passenger side dash panel that irritates me.
U.S. & Canadian Tint Laws jc21 Inside and Out 42 11-24-2008 05:46 PM
Front Passenger side rattle above 65mph jimmychoi Mechanical Problems & Technical Chat 15 07-12-2008 03:41 AM
Passenger Side Door Lock Luca88 Mechanical Problems & Technical Chat 20 10-01-2007 01:49 PM
Passenger Side Vent Is Rattling.. drexp2000 Mechanical Problems & Technical Chat 2 06-05-2007 12:17 AM
Dent in rear passenger quarter panel :( Jo Towers Mechanical Problems & Technical Chat 11 06-05-2007 12:15 AM
