Old 07-07-2007, 08:18 PM   #1 (permalink)
saskwatch420's Avatar
Kevin
Rattle noise in headliner
Has anyone else had a rattle in their headliner. Mine does in town on bumpy roads and on the highway. However, it goes away if I hold my hand on the headliner, but as soon as I let go it starts again. Also it doesn't do when I have the moonroof visor closed. If anyone has had this problem and found a solution, I would appreciate the info on how to fix this problem. Oh ya the sound is located about in the middle center of the headliner.
saskwatch420 is offline   Reply With Quote
Old 07-07-2007, 10:15 PM   #2 (permalink)
mine is doing the same thing. i only had it for 5 days. i am taking to to the dealership. Its noticeable and i told them that its coming from the moonroof.
JATT is offline   Reply With Quote
Old 07-07-2007, 10:59 PM   #3 (permalink)
My car had this problem too. It is not an intermittent rattle.
You need to lubricate the rubber seal around the moonroof with silicone lubricant. Just spray it on a rag and wipe the seal down. This will instantly get rid of the rattle you hear when the moonroof is closed.
For the record, you should be lubricating all of your rubber seals (doors, trunk, moonroof, hood) on a regular basis, at least twice a year, for waterproofing and smooth operation. Your seals will last for decades if you follow this routine. It's called silicone spray or silicone lubricant, and can be found at any auto store. DO NOT buy silicone grease, it is a totally different thing!
televascular is offline   Reply With Quote
Old 07-08-2007, 12:15 PM   #4 (permalink)
thekurgan's Avatar
Victor Kurgan
Try using the 3M anti-squeal tape, I liked the paint section of my car where the sunroof meets the metal and it solved all those problems, doesn't make a sound at all, any time, even in the cold.
thekurgan is offline   Reply With Quote
Old 01-14-2008, 02:53 PM   #5 (permalink)
NcSi's Avatar
Bryan
if its from the back pull the head linear down a little....and check the clip. if needed replace it
NcSi is offline   Reply With Quote
Old 01-14-2008, 02:55 PM   #6 (permalink)
Leonard1818's Avatar
Leonard
Are you saying to apply silicone spray directly to the rubber on the sunroof/trunk where it seals?
Leonard1818 is offline   Reply With Quote
Old 01-14-2008, 04:08 PM   #7 (permalink)
Spraying it on a rag or paper towel and using that is much easier, with no risk of overspray.
Old 01-14-2008, 07:59 PM   #8 (permalink)
Silver_Slug's Avatar
Dan
You can also buy Shin Etsu grease from Honda. Apply from the tube to a shop cloth and apply sparingly. I imagine this is what the dealer will do for you also.
Dan
Silver_Slug is offline   Reply With Quote
06-07 (2D & 4D) Civic & Civic Si Rattle or Ticking Noise ProspeedCTR Mechanical Problems & Technical Chat 6 03-21-2007 11:12 PM
Loud rattle / "clunking" in trunk area... HELP! Red S Eye Mechanical Problems & Technical Chat 10 02-14-2007 03:06 PM
07 Si Sedan rattle noise? 07CivicSiRacer Mechanical Problems & Technical Chat 3 12-11-2006 01:11 AM
Mini DIY - Fixed my elusive door rattle PokeyD16Z Do It Yourself Articles 6 09-13-2006 10:17 PM
Spinning noise gradually increasing as RPM goes up joonoo Mechanical Problems & Technical Chat 0 09-03-2006 02:54 AM
