Si MTF comes overfilled - 8th Generation Honda Civic Forum
Old 07-07-2007, 03:41 AM   #1 (permalink)
New 07 Si Sedan with 4700 miles. Like many other people, I've been having problems shifting into 3rd. Sometimes it feels like it doesn't want to go in, and I could feel and hear the resistance, pretty nasty noise. I've discovered a method to reduce the likelihood of it happening, but it requires a conscious effort where I'd have to remind myself "Hey it's that 2nd->3rd gear shift you better do this". If I forget, or try to shift too fast
Had 2 dealerships look at it and all they can tell me is that I'm shifting too fast (wth's a short shifter in the Si for anyways?). I told him no, because then i'd have problems with all the other gear changes too not ONLY 2nd->3rd, but they still won't admit the problem. One (Huggins Honda) even blew me off when I offered to try and demonstrate the problem to their mechanic(after their "2 best technicians" couldn't replicate the problem) - they told me to make an appointment and come back.
I decided to take matters into my own hands and try to go home and swap the MTF with the new Honda MTF #9031. But when I opened the fill hole oil came POURRINGG out. Turns out my MTF was overfilled, by almost half a qt... WTG Honda...
That helped with the 3rd gear a little, but I'm still not satisfied. Thinking about calling the dealership up and telling them what happened, think they'll believe me? I'm tired of wasting my time with these people... I went ahead and even ordered the AMSOIL MTF (my last resort since I didn't want to use non-Honda "genuine" MTF). Probably will change it next weekend when it gets here.
Just giving a heads up to next Si guy/gal out there that has a notchy 3rd, check out your MTF
bangmonsta is offline
Old 07-07-2007, 03:53 AM   #2 (permalink)
mrk
mrk's Avatar
Yeah, I had a similar thing happen too. I was in auto shop and I brought my car in to change the MTF and I told my shop teacher that it keeps popping out of 3rd because the tranny was overfilled. He said the same thing "Are you sure you're not just shifting too fast?" He says that trannys are hard to overfill and doubts that changing the MTF would help my problem. So I got my Si on the lift and took the fill plug out and out comes a bunch of oil. He was surprised to see it. Then I just changed my MTF to Amsoil like many others on this board and it's fine.
mrk is offline   Reply With Quote
Old 07-07-2007, 04:09 AM   #3 (permalink)
Amsoil ftw!!!
Just changed mine last weekend. It really made a difference.
M. F. Ruckus is offline   Reply With Quote
Old 07-07-2007, 05:05 AM   #4 (permalink)
Pillar of Objectivity
Special Ringpop's Avatar
The dealership probably won't care / believe you when you tell them the MTF was overfilled.
Almost every Honda dealer I've been to has a Secret Society when it comes to Civic problems. They refuse to acknowledge the quite generous problems that plague our vehicles.
Special Ringpop is offline   Reply With Quote
Old 07-07-2007, 05:45 AM   #5 (permalink)
Probably because if they acknowledge a problem, they'd get 102704 other owners that think they have that problem and want a free fix. In which cases, maybe 5% of those people ACTUALLY do have that problem, sucks for them... or in this case, sucks for me cuz i'm one of them
bangmonsta is offline   Reply With Quote
Old 08-17-2007, 07:04 PM   #6 (permalink)
07 Si sedan 6 speed tranny overfilled from factory here
Changed the stock MTF with Amsoil today, and the tranny was overfilled by about 1/4 QT when I asked the tech to remove the tranny filler plug first to verify if the tranny was overfilled from the factory.
07black_si_sedan is offline   Reply With Quote
Old 08-17-2007, 07:16 PM   #7 (permalink)
memax06si's Avatar
Ocho Cinco
Is this overfill specifically an 07 problem, or have others found the same thing? I have an 06 coupe and although I've never found it extremely hard to go from 2nd to 3rd (nor has it popped out of gear) I feel it could be much smoother. I guess it wouldn't hurt to swap it out and give it a try.
memax06si is offline   Reply With Quote
Old 08-17-2007, 08:31 PM   #8 (permalink)
"Ridge"Racer's Avatar
Justin
whats the weight of the mtf amsoil i should use, i just put in their synth oil in and it seems great. need to know the weight of the amsoil mtf. thanks
"Ridge"Racer is offline   Reply With Quote
Old 08-17-2007, 09:51 PM   #9 (permalink)
http://www.amsoil.com/StoreFront/mtf.aspx
That is what you need, 2 bottles of it
Old 08-17-2007, 09:52 PM   #10 (permalink)
It's an 06/07 problem, RSX type S also had similar problems, but not ALL of us have the problem...
You're one of the more lucky ones
Old 08-17-2007, 10:16 PM   #11 (permalink)
subscribed.
phenominalee is offline   Reply With Quote
Old 08-17-2007, 11:42 PM   #12 (permalink)
Justin
thanks, i thought thats what i needed, just thought is was weird that it just so happens to be the same viscosity as the oil for the engine even though its specified for the tranny. thanks again man!!!
AMSOIL MTF fluid vs "new" honda MTF fluid AznSupastar Civic SI 169 10-27-2011 10:06 PM
Redline MTF or Amsoil MTF Jardiniboy Civic SI 36 10-19-2009 12:20 PM
Honda mtf or Amsoil mtf? b0yd07 Civic SI 38 06-10-2007 06:16 PM
New Honda MTF, 3rd Gear (Already Covered, I Know) pinchycm Civic SI 14 05-18-2007 02:20 AM
To replace MTF or not to replace MTF! thats the question 93sidood Mechanical Problems & Technical Chat 28 03-24-2007 02:48 PM
