Old 07-07-2007, 01:06 AM   #1 (permalink)
little ss fix...
ok so i had my ss installed for a long time now as well as the base bushings
i later purchased the corsport shifter cable bushings and well everything worked fine...
until it started getting weird going into 4th and 2nd gears and 6th as well...it seemed all the "lower" gears (gears that go down) are giving trouble...so i was like.. what the heck? ya it seemed like they were going in way too stiff to be normal, sometimes it felt like i wasnt even going in at all, but were engaged indeed. it bothered me for a while because i was getting no "ffedback" per se on the gears...
anywayz after testing it like mad and checking everything, i realised that the little adapter moved everything down and so the black cover that goes onto the blue cap was rubbing the bottom black mount (where the base bushings go)
so i removed everything, pulled out the cotter pin, moved the black cover over, so the blue cap is exposed, and grinded the shit out of the black mount where it was rubbing...
result : NO MORE TROUBLE!!!!!!!!!
woo i feel good now
if anyone has quesitons, feel free, or share your experience with this same problem, thanks
rkalloo is offline   Reply With Quote
Old 07-07-2007, 01:09 AM   #2 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
i broke a piece of the shift cable that holds the cable bushing. it did the same thing but it wouldnt go into those gears.
Originally Posted by NBPRudy View Post
:failmyharryballs:
http://killyourself1.myminicity.com/env build my city.
Old 07-07-2007, 01:57 AM   #3 (permalink)
projekt1's Avatar
woo i feel good now
Good to kno cause i plan on buying these soon...
+1
projekt1 is offline   Reply With Quote
Old 07-07-2007, 02:48 PM   #4 (permalink)
no my problem wasnt with the cable bushings, it was with the shifter itself..the mechanism inside the car
Old 07-07-2007, 04:01 PM   #5 (permalink)
pure2.0's Avatar
woo i feel good now
I had to do this too.....
pure2.0 is offline   Reply With Quote
how to Fix my Rims Please help 8th Rican768 Wheel And Tire Upgrades 14 09-14-2008 10:19 PM
Petition to Honda to Fix Nav Unit ericsandgo I.C.E., Electrical, Security, & Navigation 23 05-29-2008 12:57 AM
How-to Fix the rear deck/subwoofer rattle (less than 5mins fix) HardBoiler Mechanical Problems & Technical Chat 48 05-03-2007 08:11 PM
Fix It Ticket Question SIg Garage 10 04-12-2007 01:14 AM
2 week dealership fix tomasro Mechanical Problems & Technical Chat 7 04-27-2006 05:57 PM
