Old 07-05-2007, 08:36 PM   #1 (permalink)
CaliGuy's Avatar
J. M. back by popular demand!
Problem after IMG install
I installed my IMG last night and everything was fine, drove to work today no prob (except it seemed like vtec wasn't kicking in hard)...
Anyway, coming home from work today I downshift and mash the gas to pass and the car hits out 5.5k and the RPMs just drop and then recover, this happens a few more times and then I get a CEL. I pushed it hard again anfer a few minutes and no problem. CEL is still on though!
Any thoughts?
Old 07-05-2007, 08:37 PM   #2 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
did you tighten everything up. maybe something came loose?
Originally Posted by NBPRudy View Post
:failmyharryballs:
http://killyourself1.myminicity.com/env build my city.
Old 07-05-2007, 08:38 PM   #3 (permalink)
Brodie
atruhondagrl's Avatar
Air leak somewhere? A hose not hooked up correctly?
AWD is RWD with training wheels.
atruhondagrl is offline   Reply With Quote
Old 07-05-2007, 08:39 PM   #4 (permalink)
DATA02's Avatar
hummm, I wouldn't push it too hard until you figure out what went wrong. All you can really do is check over everything and make sure nothing got snagged. anywho best luck man!
DATA02 is offline   Reply With Quote
Old 07-05-2007, 08:42 PM   #5 (permalink)
06BlackSi's Avatar
i remember seeing a thread with this situation... cel after img install... can't remember if it was here or not...
i think i remember the problem to be an air leak. like the others have recommended, double check the install and make sure all the bolts are torqued to spec.
06BlackSi is offline   Reply With Quote
Old 07-05-2007, 08:48 PM   #6 (permalink)
CaliGuy's Avatar
Ya, I thought maybe a vacuum leak, but why would it be intermittent then?
Old 07-05-2007, 08:51 PM   #7 (permalink)
DATA02's Avatar
If I remember that thread correctly it was intermittent because of when the engine heated up something expanded and reduced the space of where the leak was. I think..
Old 07-05-2007, 08:58 PM   #8 (permalink)
CaliGuy's Avatar
Well, now I go out and start it up again and no CEL! Oh well, I got an appt at Honda tomorrow if I can't figure it out...
Old 07-05-2007, 09:05 PM   #9 (permalink)
nevertofast's Avatar
dont tell them sh!t about u changing the gasket they will void your warrenty
nevertofast is offline   Reply With Quote
Old 07-05-2007, 09:09 PM   #10 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
i think they will notice either way.
:failmyharryballs:
Old 07-05-2007, 09:22 PM   #11 (permalink)
CaliGuy's Avatar
Well, I'm not here to get into another warranty argument.
On a side note: I am a complete f'n retard...
I didn't tighten the fuel rail ground wire that was staring me right in the f'n face!
Old 07-05-2007, 09:24 PM   #12 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
jarjarjar hahahha. nice one.
:failmyharryballs:
Old 07-05-2007, 09:29 PM   #13 (permalink)
CaliGuy's Avatar
Is all I could think when I found the problem was Carlos Mencia: DEE DA DEE
+Rep to all those that helped! Thanks guys and gal!
Old 07-05-2007, 09:38 PM   #14 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
how hard was the install. ive had my img for months and havent tried it. the only part that worries me is removing the bolts on the bottom.
:failmyharryballs:
Old 07-05-2007, 09:40 PM   #15 (permalink)
BATANG CITY JAIL's Avatar
so how is it now? they said it dont matter where ground up the injector wires,but i still put min on one of the bolts up in the valve cover..
Old 07-05-2007, 09:44 PM   #16 (permalink)
well you could do whatever you want to your car but once you throw a check engine light you void your warrenty not arguing just telling you how it is
Old 07-05-2007, 09:45 PM   #17 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
A cel doesnt void your warranty. how would that be possible. it is supposed to warn you that something is wrong. your cel could come on if your dont close your gas cap eneough.
:failmyharryballs:
Old 07-05-2007, 09:54 PM   #18 (permalink)
CaliGuy's Avatar
It's not easy. Just follow Q-Shooters DIY and you'll be ok. It just takes a long time 5-6 hours.
If you follow Q's DIY and remove the front bracket thingy you can get to the lower bolts no problem.
Old 07-05-2007, 09:55 PM   #19 (permalink)
CaliGuy's Avatar
Fine now. No problems at all...
Old 07-05-2007, 09:56 PM   #20 (permalink)
Ahhh! Domokun!
Ruthless909's Avatar
4dr WhOrE!!!
Glad you got the problem fixed!!
Ruthless909 is offline   Reply With Quote
Injen CAI Install problem s1deout Bolt-Ons And All-Motor 15 06-18-2007 05:29 PM
rear shock problem ziggy Mechanical Problems & Technical Chat 30 04-07-2007 08:48 PM
RE: Galaxycivic Amp problem damon300s I.C.E., Electrical, Security, & Navigation 2 12-26-2006 11:48 PM
Problem with SS Coilover install legendman Suspension and Brakes 10 12-14-2006 12:39 AM
Car audio install problem.......Pioneer AVIC N1 pittcwhite Inside and Out 1 07-26-2006 02:09 AM
