mechanical engine sound
I have 12,000 mile on my Civic and have noticed a slight clicking sound in the passenger compartment when the engine idles or accelerates. I know the Civic has adjustable valve clearance. Is this sound just characertistic of the engine after it is broken in?
I don't remember hearing this when the car was new.
![]() Join Date: Feb 2006
Back and Forth Forever
I (think) I've heard a similar sound. Almost a knocking sound? Mine only does it when I start it in the cold. After it warms up, I'm good to go. Maybe it's not the same sound...I dunno.
My coupe is doing the same at 13K miles, the car was very quiet when it was new. I wonder if it is the oil that makes the difference? may be it is valve resonance. My accord did that in winter more then summer, I think it’s the thin oil 5W20, I am going to try 5W30 synthetic oil next oil change…
Big difference, today I took may car for an oil change, and got SAE 5W-20 Full Synthetic Motor Oil. I no longer hear the engine's mechanical resonance, even when the car is fully warm and idling at about 600 RPM. Big Difference!!!
I believe this oil is made by Ford Motor Company.... Let see how long this holds up… i'll let you guys know... |
#8 (permalink) | |
Think you guy's might be due an oil change, my engine is still pretty silent at 12,000 miles.
This is a full synthetic and might I add $4.25/quart and the car is silent as never before.
I have gotten oil change from Honda dealer and had the same issue… but this OIL is damn good…… http://www.fcsdchemicalsandlubricant...ry=Motor%20Oil |
#10 (permalink) |
Motorcraft® SAE 5W-20 Full Synthetic Motor Oil is a premium-quality passenger car motor oil designed, engineered and recommended by Ford Motor Company meeting warranty requirements. It is API Certified for gasoline engine service ILSAC GF-4 and meets API SM/Energy Conserving
Motorcraft® SAE 5W-20 Full Synthetic Motor Oil is manufactured with high-viscosity index, premium-quality, synthetic base oils that provide good high temperature and low temperature performance. It helps minimize engine deposits and wear, protect against high-temperature oxidation, low-temperature gelling, rust and corrosion and foaming. The friction-reducing technology in this motor oil provides superior wear protection and energy-conserving characteristics, which result in significant improvement in fuel economy when compared to SAE 5W-30 and 10W-30 motor oils Refer to the Motorcraft® SAE 5W-20 Full Synthetic Motor Oil specification sheet at www.motorcraft.com and www.fmcdealer.dealerconnection.com for additional information. For MSDS information call 1-800-448-2063 |
| red H emblem for new civic? | DeezSi06 | Civic SI | 7 | 12-24-2006 09:52 AM |
| All The SEMA Pics You Want (New) | Kabs | Civic SI | 4 | 11-15-2005 01:53 AM |
| help with bulbs sizes??? | youngxlos | Civic SI | 6 | 11-06-2005 11:56 AM |
| Improve your stock EX sound system. | unplugged | I.C.E., Electrical, Security, & Navigation | 4 | 11-04-2005 09:25 PM |
| 2006 Civic to be road tested on Motorweek T.V. | 2fast4u2 | Garage | 18 | 11-04-2005 01:09 AM |
