Help! Can't get into reverse!
The reverse gear on my 2007 Si just died on me today. It started giving me trouble this week when it became realy hard to engage the reverse. I would be able to get it into the reverse position, but it wouldn't engage(the clank sound). Now, when I try to put it in reverse, it seems like nothing's there. The "wall" between 6th and reverse seems to be gone... I installed the corsport shifter bushings a while ago, could that be why its messed up?
The only mods I have is Comptech ss, twm base bushings, and corsport shifter bushings. Thanks in advance. |
#2 (permalink) | |
I dont have the mods, but by the looks of the install guides and whatnot, it's a pretty good assumption that your problem lies in the replacement parts. I'd take it apart and at least have a peek to make sure it all looks groovy.
I saw the thread and immediately thought electrical cable stuck due to CAI install. I had that problem initially when I installed my CAI before I cable tied everything. Shifting (on the lift) was difficult, then saw the cable jammed in there. Oops! |
From pg 197 of the owners manual:
1. With the clutch pedal pressed, moe the shift lever to the first/second gear side of the neutral gate, then shift to reverse. 2. If you are still unable to shift to reverse, apply the parking brake, and turn the key to the ACCESSORY (I) or LOCK (0) position. 3. Press the clutch pedal, and shift into reverse. 4. With the clutch pedal still pressed, start the engine. If you need to use this procedure to shift to reverse, your vehicle may have developed a problem, such as non-OEM aftermarket bushing installation. Have the vehicle checked by your dealer. |
#5 (permalink) | |
#8 (permalink) | |
Yeah I got the same thing going on with my car....I have to tug my cable towards the passenger side get back in my car pop it in reverse if it works, get back out close my hood and start my car. Anyone know what part I need to get to do the fix...Thanks...
#13 (permalink) | |
#14 (permalink) |
I took a good look at it today while my friend was shifting through the gears.
This is how it looks when I open the hood... ![]() This is what I can do with the sleeve..It is in no way connected ![]() This is what it looks like after I re-allign the cable to get it into reverse
#19 (permalink) |
Supreme Pizza!
Do all of you have the cable bushings installed? The pictures up there looks like the cable loosened up and it shouldn't be....The plug should at least always be hovering just inside that plug...wierd. I'll look under my hood later, to confirm. I don't have the cable bushings, btw.
| Reverse Lights | si_turbo | Lighting, H.I.D.'s, & Neon | 10 | 06-07-2007 01:34 PM |
| Reverse Gear Grinding.... | Kenbeal | Driving Experience | 20 | 12-20-2006 03:16 PM |
| Can't shift into 3, 4, 5, or reverse, wtf? | zoltanh | Mechanical Problems & Technical Chat | 3 | 11-25-2006 08:49 PM |
| MY SI WONT GO INTO REVERSE!!!!!! | dannyboy's06Si | Mechanical Problems & Technical Chat | 7 | 09-04-2006 03:47 PM |
| removing the reverse light | cojaro | Inside and Out | 6 | 05-11-2006 04:32 PM |
