Old 06-27-2007, 01:54 AM   #1 (permalink)
hondasi006's Avatar
electronic power steering problem
ive posted this up before, i get in the car and start it up, go to turn the wheel and it jerks like a half an inch and locks up cuz the power is dead, and the eps light is on the dash. i have taken it to the dealership but they couldnt find the problem. it happens every now and again, all i do is shut the car off and restart and its fine. just curiouse if any one has had the same problem
hondasi006 is offline   Reply With Quote
Old 06-27-2007, 10:47 AM   #2 (permalink)
hondasi006's Avatar
no one, huh
Old 06-27-2007, 11:04 AM   #3 (permalink)
Nighthawk07's Avatar
Mikey
Hmm.. that's weird. Hasn't happend to me. Sorry I can't help.
Nighthawk07 is offline   Reply With Quote
Old 06-27-2007, 11:38 AM   #4 (permalink)
drexp2000's Avatar
They should have pulled up a DTC code from the EPS system.
Is it a reoccuring problem or just a one time deal? Might want to go a different dealer, EPS system might be faulty..
drexp2000 is offline   Reply With Quote
Old 06-27-2007, 11:43 AM   #5 (permalink)
hondasi006's Avatar
it is a reoccuring problem, i normally let the car idle after start up until 1500 rpm. if i wait a lil longer than that then i got to turn the wheel it locks, it doesnt happen every time but just enough to piss me off. \
the dealership i went to looked at it and said that unless the car is here while the eps light is on then they can not tell what it is, so i am trying to figure out if i can make the light go on while i am there, because i am not goin to drive about 15 min on a major highway to the delership with the eps off.
Old 06-27-2007, 12:33 PM   #6 (permalink)
drexp2000's Avatar
That's odd.. Usually they could pull up (Using the HDS) a history of DTC codes. Unless the problem you are having does not have a DTC associated to it. It might be mechanical more so than ECU related... I have my dealer service manuals at home, I'll dig up some stuff for you when I get home.
Old 06-27-2007, 12:38 PM   #7 (permalink)
hondasi006's Avatar
thanks alot. i know it sounds easy,"just take it to the dealership".
i really dont want to drive it there in that condition, or have to leave it there over night so when it starts up for the first time in a couple of hours it will set the eps light on the dash, let me know what you find, thanks again
Old 06-27-2007, 01:51 PM   #8 (permalink)
Do you have a race header on?
bioevolve is offline   Reply With Quote
Old 06-28-2007, 01:29 AM   #9 (permalink)
hondasi006's Avatar
no, i did read that thread about the guy that got the header and the heat shield melted the wires, thats not my case.
it has never acted up while i was driving, if it did i would be like
it mostly happens in the winter while i let it warm up ( agian i dont wait like 10 min or nothing, just till about 1500). im sure someone had this happen,
other mods that might maybe just a lil have something to do with it,
8k hid kit
custom led bars and neon inside
Old 06-30-2007, 10:56 AM   #10 (permalink)
Excalibur's Avatar
Jeremy
That's wierd. I hope you get it figured out.
Old 10-01-2007, 02:53 AM   #11 (permalink)
leetcoder's Avatar
Sorry to bring this thread up.. Im having the same problem with my power steering. Sometime the eps light will come on when i start up the car and I have to turn off the car and start the car again for the power steering to work again. Did you fix yours yet hondasi006?
leetcoder is offline   Reply With Quote
List of problems with my LX Coupe 5sp. vtecharry Civic Coupe And Sedan 220 03-11-2007 06:47 PM
what power source do I use to power my neons in car? Way2Short Lighting, H.I.D.'s, & Neon 16 10-20-2006 01:57 PM
power steering ??? tc5953 Civic Coupe And Sedan 7 05-02-2006 08:27 PM
