Old 06-25-2007, 01:15 AM   #1 (permalink)
Mateen's Avatar
A/T 1st to 2nd rough shift at low RPM.
I have this issue with my ex Coupe A/T which has not been discussed on this forum and I am just wondering if this is a common issue or not.
When I'm driving lets say in a parking lot looking for a space, driving in first gear in low rpm. When the rpm reaches to about 1700, the car would make a rough upshift to 2nd. It is so rough it kind of shakes the car.
Mateen is offline   Reply With Quote
Old 06-25-2007, 01:49 AM   #2 (permalink)
Yeah, I get that, too. I guess it's the characteristic of the car, never really bothered me.
Old 06-25-2007, 01:57 AM   #3 (permalink)
iknowmysh1t's Avatar
check your mounts.
iknowmysh1t is offline   Reply With Quote
Old 06-25-2007, 03:11 AM   #4 (permalink)
happens to me also
especially in traffic where it rarely goes above 10mph
i go from 8-10mph, then let off the gas, i hear and feel a jolt/shudder. Then i press the gas and the car jolts forward.
Old 06-25-2007, 03:17 AM   #5 (permalink)
Firestrife's Avatar
Keenan
Originally Posted by jasongg06
happens to me also
I think thats the transmission trying to upshift but when you let off the gas you didnt let it do it so it kind of jolts trying to downshift right afterward. I had some kind of similar effect on my corolla.
Firestrife is offline   Reply With Quote
Old 06-25-2007, 12:53 PM   #6 (permalink)
Mateen's Avatar
My problem is when I am in 1st gear and going very slowly like 8-10 mph (low throttle), the transmision would upshift to 2nd at around 1700 rpm and I can feel a big jolt from the tranny which sounds like a very hard upshift to 2nd.
this only happens when the upshift to 2nd happens around 1700 rpm (very low throttle). If I push on the gas and let it accelarate to anything over 2200 rpm then the upshift to 2nd is smooth.
Old 06-25-2007, 03:34 PM   #7 (permalink)
BigT's Avatar
This may simply be the way the shifting of this car is tuned. However, many tranny computers attempt to adjust to the way you drive. The car tries to anticipate the way you are going to accelerate based your "normal" driving and shift accordingly. If you normally accelerate rather briskly, the car shifts harder to avoid excessive slippage. Then when you are slowly rolling along in a parking lot you get harder shifts. To see if this is the case you could try accelerating very gently for a while to see if the tranny adjusts and the problem gets better. I used to do all the maintenance on my sisters car and when I test drove it afterwards the car would just about jerk me out of the seat when it shifted because the computer was adjusted to her lead foot . If I had to drive the car very far, the shifting would smooth up. My $.02
BigT is offline   Reply With Quote
Old 06-26-2007, 01:17 AM   #8 (permalink)
Mateen's Avatar
That is pretty interesting. I will do some tests based on your theory and will report back.
Thanks.
Old 06-26-2007, 02:38 AM   #9 (permalink)
nese005's Avatar
Panda
very interesting
nese005 is offline   Reply With Quote
All vtecs are not created equal GeezerSi Water Cooler 3 06-18-2007 06:47 PM
1st to 2nd gear grinding at high rpms pate2901 Mechanical Problems & Technical Chat 2 04-22-2007 02:19 PM
07 Problems todsulli Mechanical Problems & Technical Chat 33 01-29-2007 10:38 AM
best RPM for launch and shift el_ben2 Autocross & Sanctioned Drag Racing 2 04-20-2006 10:39 PM
