Old 06-24-2007, 11:45 AM   #1 (permalink)
93sidood's Avatar
Rotor is shot... Warped?
My rotor has been making squeeking noises at all speeds. and finally tonight it started making HARSH rubbing noise when i come to a stop. I am thinking it is warped. If i look at the rotor, the outer edge has actually been grinded down and is rough and uneven because of the problem with the brake. It seems to be only on the front left side. What can i do to fix it? what do i need? what would be an estimate for repairs??
93sidood is offline   Reply With Quote
Old 06-24-2007, 12:31 PM   #2 (permalink)
spooned06civic's Avatar
chris
how many miles are on ur car
if u are under 10k u can go to the dealer as a brake defect
it is considered a wearable item on a car but there is not brake rotor or brake pad out there that will get screwed up so bad on a new car that u shake and squeek i beat the crap out of my 06 civic lx and i still got 22k outa my brake pads and rotors before i had to recut the rotors and replace the pads
spooned06civic is offline   Reply With Quote
Old 06-24-2007, 06:42 PM   #3 (permalink)
Front or rear? I front and it's warped you will feel pulsating in the brake pedal.
Old 06-24-2007, 07:02 PM   #4 (permalink)
TJ06CivicLX's Avatar
Sounds like your pads are worn down. And probably so much now that the rotors got screwed up. It was squeaking for a reason (Telling you to change your pads). Doesn't sound like a warped rotor.
TJ06CivicLX is offline   Reply With Quote
Old 06-24-2007, 07:26 PM   #5 (permalink)
Tim
Yah I had to get my rotors turned at 26,000 miles, they were warped bad. Lots of grinding when I stopped. Of course, the dealer says they turn the rotors for free up to 25,000 miles, and what do I have, 1,000 miles over that...so they charged me $80 bucks lol. Oh well, brakes felt new after they did it.
trogers8 is offline   Reply With Quote
Old 06-25-2007, 04:53 PM   #6 (permalink)
BigT's Avatar
I agree that it doesn't sound like a warped rotor. A warped rotor can give you a feeling like the car surging slightly while stopping or more commonly a pulsation in the brake pedal. If you have low mileage and the problem is only on one side you may have a stuck caliper, causing that side to wear prematurely. If this is the problem it should be covered under warranty. However if you have racked up some miles the pads may simply be worn out. A squealing/squeaking at all speeds could be caused by the pad's wear sensor. It is a simple tab of metal which rubbs against the rotor when the pads get low and make a high pitched noise to let you know your pads are low. If you drive like this very long the pad will wear away completely and you will get metal to metal contact causing the grinding.
BigT is offline   Reply With Quote
Old 06-25-2007, 05:33 PM   #7 (permalink)
NIGHTHAWKSI's Avatar
Ian
i agree...sounds more like worn out pads than bad rotors....although since you have been riding on work out pads for some time now they will need to be resurfaced.
NIGHTHAWKSI is online now   Reply With Quote
Old 06-26-2007, 02:16 AM   #8 (permalink)
Rotors never really warp. They crack or "cone" under high stress.
A truly warped rotor cannot be resurfaced; it must be thrown out. If you were able to get them resurfaced, it means the pads or other component wore the surface unevenly. This is not "warping".
Another possible scenario is that, during a tire rotation or some such procedure, the rotor had binded or the wheel was torqued incorrectly. The rotor would not be flush with the wheel hub, causing vibration and uneven wear. Maybe the grinded edge of your rotor was caused by a dragging caliper, who knows.
...But are you absolutely sure it's not just the wear tab on the pads making all that noise?
televascular is offline   Reply With Quote
mug shot - LOL LOOK AT THIS webby Water Cooler 26 08-28-2008 03:05 PM
Proof - eminem's best friend shot dead in detroit webby Water Cooler 21 06-02-2007 03:25 PM
75 shot of nos safe for stock block? adamhoud Forced Induction And Nitrous 15 10-30-2006 12:57 PM
The Rolling Stones atruhondagrl Movies & Music Reviews 15 10-21-2006 09:35 PM
New Digital Camera- 39MB -117 megs per shot webby Water Cooler 1 07-18-2005 10:59 PM
