Old 06-22-2007, 06:08 PM   #1 (permalink)
TeamValorRacing's Avatar
need torque settings!
hey, i just got my flywheel and disc. i have the tq settings for the flywheel to motor and bel housing specs, but i need the tq rating for the actual clutch pressure plate to the flywheel. if anyone has a helms and could look that up for me it would be great. -nathan
TeamValorRacing is offline   Reply With Quote
Old 06-22-2007, 08:40 PM   #2 (permalink)
I'm feeling generous today.
Assuming you are talking about an Si...
"Install the pressure plate and the mounting bolts finger tight.
Torque the mounting bolts in a crisscross pattern. Tighten the bolts in several steps to prevent warping the diaphragm spring.
Specified Torque: 25 N-m (2.6 kgf-m, 19 lbf-ft)"
televascular is offline   Reply With Quote
Old 06-22-2007, 11:48 PM   #3 (permalink)
thanks very much man, that really helped me out. i cant believe all they need are 19ftlbs, crazy. Again, thanks.
Nissan SE-R Spec V Smokes Civic Si junsu Civic SI 193 06-28-2007 03:22 AM
Amp settings help, please! SiC17 I.C.E., Electrical, Security, & Navigation 8 09-16-2006 01:00 AM
Torque Settings on AntiSway Bar 1CLNSEDAN Suspension and Brakes 4 09-14-2006 03:00 AM
torque specs ??? BLU BY U Suspension and Brakes 4 07-15-2006 04:21 PM
Torque wrench 8thgenuser Mechanical Problems & Technical Chat 8 03-24-2006 08:40 AM
