Old 06-21-2007, 11:21 PM   #1 (permalink)
mrd
FG1 Differential
I know the FG2 comes with a Limited-Slip Differential, and the FG1 doesn't. I assume the FG1 has an open differential. I am wondering if it's possible to put in an aftermarket differential, like a Quaife or Torsen.
I'd assume the way to find a matching diff would be to find one that fits the housing. I tried finding some kind of code that identifies the housing for the diff on the web, but no luck. Best I found was it appears, from pics off a parts site, the same housing that holds the diff also contains the transmission.
Any ideas?
mrd is offline   Reply With Quote
Old 06-21-2007, 11:22 PM   #2 (permalink)
Skylinegtr06's Avatar
edwyn(male)
an Fg1 has a differential in it?
Old 06-21-2007, 11:25 PM   #3 (permalink)
mrd
An open differential, I'd assume. Standard stuff.
Old 06-21-2007, 11:29 PM   #4 (permalink)
BATANG CITY JAIL's Avatar
like the one that you found in subaru? or any RWD?
Old 06-21-2007, 11:31 PM   #5 (permalink)
edwyn(male)
hmm I dont know We need some honda techs in here
Old 06-21-2007, 11:34 PM   #6 (permalink)
btw.. yes u can put any aftermarket diff in it....
Old 06-21-2007, 11:35 PM   #7 (permalink)
mrd
I'd imagine a RWD diff would differ from a FWD diff, since the RWD diff is less cramped and is probably oriented differently due to the input shaft's orientation.. but the function is the same, distribute power to the wheels.
Old 06-21-2007, 11:35 PM   #8 (permalink)
udumkid's Avatar
Rene....
Yes, But you will have to open the transmission casing in order to install the limite slip gear. In other words you are better of buying a trans with limited slip than actually modifying one that does not have one.
udumkid is offline   Reply With Quote
Old 06-21-2007, 11:36 PM   #9 (permalink)
mrd
Yes but I need to find one that fits!
Old 06-21-2007, 11:38 PM   #10 (permalink)
why ask the forum? if u already know?
Old 06-21-2007, 11:42 PM   #11 (permalink)
mrd
Old 06-22-2007, 12:13 AM   #12 (permalink)
mrd
A diff might run a grand, a diff + tranny, ouch I don't want to know how much.
I don't believe replacing the diff would be too much work. Hard part would be lowering & raising the housing, I'm sure she's heavy.
Alas, I can't do anything if I can't find a diff that will fit.
Old 06-22-2007, 12:40 AM   #13 (permalink)
t('.'t )
m1k3's Avatar
i hope you get what your looking for.
its about time we get some better info/stuff for the fg1's.
06 FG1 LX MT
AEM CAI | Magnaflow Cat-Back | Comptech SS | TWM Bushings | Eibach Prokit | Enkei Evo 6
m1k3 is offline   Reply With Quote
Old 06-22-2007, 10:16 PM   #14 (permalink)
udumkid's Avatar
Rene....
You are forgetting that there is alot of clearance measuring involved,have seen many lsd's go bad when people dont do the job right.
Old 06-23-2007, 12:23 AM   #15 (permalink)
jspecFG's Avatar
Well, if you truly wanted too; you can swap the FG2 lsd into your FG1 tranny, it's been done already actually. It works, but who knows what kind of problems might appear.
jspecFG is offline   Reply With Quote
Old 06-25-2007, 05:18 AM   #16 (permalink)
I am
ex5coupe is offline   Reply With Quote
Old 06-25-2007, 05:20 AM   #17 (permalink)
edwyn(male)
^so yeah can he put the fg2 differential?
Old 06-25-2007, 07:02 AM   #18 (permalink)
Jardiniboy's Avatar
Jasten
If you're not gonna do AutoX or circuit racing, don't waste your money on getting a LSD. Stick with open.
Old 06-25-2007, 07:08 AM   #19 (permalink)
JeShUa's Avatar
swagger so tight
Old 06-25-2007, 07:08 AM   #20 (permalink)
SlammDizzle.
Mikey6p's Avatar
Mukey
http://pdqmotorsports.net/
ask someone there. They ran with a R18 tranny and Si lsd.
Originally Posted by firmhonda
Sometimes, when I hit that "delete" button, I fap uncontrollably. When I'm done I dress as a king and force my girlfriend of 6 years to start calling me "Master" while making some of the lesser people in my neighborhood rub my face with velvet while feeding me delicacies from all over the world from a crystal bowl engraved with the numbers of all the posts I've deleted within the last 36 hours. It's a fine life indeed.
Mikey6p is offline   Reply With Quote
Worth Trading In My FG1 to FG2? kicker_jace Garage 28 06-28-2007 12:41 AM
Pictures of my FG1 rsanand Introduction & Pictures 29 06-14-2007 04:58 AM
Tein S-Tech Spring are now available for FG1, what do you think? modoko Civic Coupe And Sedan 7 08-22-2006 03:44 AM
Where to buy the Neuspeed springs for FG1 otsacto Suspension and Brakes 1 03-28-2006 02:25 AM
